ABS?
LSA9K
  • 7 months later...
Sometimes a bit of clean of the sensors and rings is all that's needed.
My ABS light has been going on and off for a few days now. Comes up as code 13 after a bridge test, which would be my passenger side front sensor. With it being intermitent, would that indicate more a dirt problem or just a sensor on it's way out? I had new outer CV joints fitted last August so I would have thought the teeth would still be clean? How do you clean the sensors? Do you have to remove the sensors to clean them? If a clean doesn't work and I have to source a second hand one, are the fronts sided or can you fit them to either side? Many thanks!
  • 1 month later...
I've had it on since last week.
It's off until a few seconds after I start moving, then lights up. Often the next day that it's off and the the same happens. Putting it down to a sensor not working anymore giving the age & mileage. But got till October to resolve it...
