aerodeckcrewser Posted September 23, 2013 Share Posted September 23, 2013 Hi all I have all my turbo kit for my c4 deck and going to be running it at low boost, can anyone recommend easy install injectors please ? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted September 23, 2013 Share Posted September 23, 2013 I would like to know also. I have some injectors, but have now discovered the plastic caps are smashed.Nissan or Mitsubishi would be a good cheap injector id say. Should be easy to install if you get the clips.Some Nissan injectors are high impedance which is ideal. Otherwise resistor box will be needed.440cc should be good for low boost. Fuel pump and adjustable fpr also Quote Link to comment Share on other sites More sharing options...
noodels Posted September 23, 2013 Share Posted September 23, 2013 worth a read if not already,like me >> http://beesandgoats.com/boostfaq/g2icturbo.html Quote Link to comment Share on other sites More sharing options...
aerodeckcrewser Posted September 23, 2013 Author Share Posted September 23, 2013 well the stuff I have been reading is really useful, a lot of U.S, use higher cc injectors due to the low fuel octane levels over there. I have then discovered turbo builds around Europe are using lower cc injectors i.e 320cc compared to U.S 440 for low boost but making the same gains using higher octane fuel. How true this is I don't know but think I am going to run around 5- ps using 320cc injectors and a 255 fuel pump on say shell fuel should be fine . Quote Link to comment Share on other sites More sharing options...
aerodeckcrewser Posted September 23, 2013 Author Share Posted September 23, 2013 oh thanks for the link noodels and really don't want resistor boxes and all that shizzle that's why I ruled out the dsm injectors Quote Link to comment Share on other sites More sharing options...
aerodeckcrewser Posted September 23, 2013 Author Share Posted September 23, 2013 And I've found this calculation which is handy for anyoneDivide required Horsepower by number of injectors used...For example if you want 200bhp (200 HP / 4 INJ.) = 50 HP PER. INJ. (50HP X .50 B.S.F.C.) = 25 Lbs/Hr (25 Lbs/Hr / .80% Duty) = 31.25 Lbs/Hr Static flow rate. 31.25 Lbs/Hr X 10.50 = 328 cc/Min. Static flow rate required. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted September 24, 2013 Share Posted September 24, 2013 That's good. Ill be aiming for around 260hp so 440cc probably about right. You don't want injectors running at full wack anyway I believe. 80% I think. Quote Link to comment Share on other sites More sharing options...
aerodeckcrewser Posted September 24, 2013 Author Share Posted September 24, 2013 Yeah I was looking for around 250bhp . Next one to look for is which fpr to use . I guess if i go for 440cc it can be tweaked a bit more if needed in the future. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted September 24, 2013 Share Posted September 24, 2013 I'm going to buy a bloc adjustable fpr. Direct bolt on part. Should be half decent quality and around 45 delivered from us of mother ducking a Quote Link to comment Share on other sites More sharing options...
aerodeckcrewser Posted September 24, 2013 Author Share Posted September 24, 2013 Ha ha . Sometimes I really feel like getting a cheap flight there picking up loads of parts and flying back post me a link if you find one. Cheers Quote Link to comment Share on other sites More sharing options...
