burbleboy Posted October 31, 2013 Share Posted October 31, 2013 I have noticed recently that after a 'hard' run there is the distinctive burnt, dry oil smell. There appears to be no smoke from the exhaust (in mirrors when accelerating hard) and on further investigation i discovered the x4 rocker cover spark plug seals were letting some oil into the spark plug area. I changed them within days, the oil cleared up but smell still there. I noticed a small haze of smoke when i stop...as if coming from the engine. I have no visable leaks though...any ideas to point me in the right direction please? Alastair Quote Link to comment Share on other sites More sharing options...
simpo Posted October 31, 2013 Share Posted October 31, 2013 Sump gasket or around the vtec solenoid prob dripping on the manifold and that's why u can smell it Quote Link to comment Share on other sites More sharing options...
burbleboy Posted October 31, 2013 Author Share Posted October 31, 2013 Aaah! The sump gasket was leaking slightly so I will get it on the ramps and see...as its obviously got worse! I checked the round seal at camshaft (as one came in the kit) but it was dry. Thanks mate Quote Link to comment Share on other sites More sharing options...
VTEye Posted November 1, 2013 Share Posted November 1, 2013 I have had a similar problem, smelt like oil dripping on my exhaust with no visible leak, i also had blue smoke from exhaust when dropping out of vtec. I read up that the PCV valve can sometimes cause the smoke from the exhaust. I left my car at my mates while i was away offshore and he had a look at the PCV valve, it fell apart when he took the hose off it. He got a new one off ebay and fitted it. The blue smoke seems to have gone and there is not oil smell anymore. The flap in the old valve was sticking and i reckon oil was dripping from it on to my exhaust. See the link below for cleaning the PCV, the picture is the PCV that came off my car. http://h-tune.co.uk/tech/?p=547 Quote Link to comment Share on other sites More sharing options...
simpo Posted November 2, 2013 Share Posted November 2, 2013 Where is that located on the engine? Quote Link to comment Share on other sites More sharing options...
burbleboy Posted November 4, 2013 Author Share Posted November 4, 2013 Traced my oil leak to n/s driveshaft seal. Theres oil along driveshaft and on gear linkage boot. £10 from honda for the seal....just the MTF oil thats feckin expensive.....as i changed the gearbox oil not that long ago **sighs and head in hands** Thanks Simpo for pointing me in the right direction Also thanks to VTEye for the effort to help out. Appreciated guys 1 Quote Link to comment Share on other sites More sharing options...
simpo Posted November 11, 2013 Share Posted November 11, 2013 U should of said I had that seal somewhere as I brought both as mine was leaking from o/s , saying that trying to find it could be a mission. Least it's sorted now Quote Link to comment Share on other sites More sharing options...
