skitzma8 Posted November 10, 2013 Share Posted November 10, 2013 Anyone know how I can go about increasing the fuel cut off limit on a D14 because mine revs just over 7k but it doesn't actually seem like its over reving or hitting the limiter. I can just tell it wants more fuel going through Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted November 10, 2013 Share Posted November 10, 2013 You'd need to remap the ecu for a higher rev limit. Which afaik you won't be able to do with the original ecu in your car. Quote Link to comment Share on other sites More sharing options...
skitzma8 Posted November 10, 2013 Author Share Posted November 10, 2013 So what ecu do I go for? And how Do I go about getting it remaped? thanks Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted November 10, 2013 Share Posted November 10, 2013 P28. P06. P30. Something like that. Possibly a conversion harness too. H tune is the easiest place to get them from. Probably sell you a chip with whatever specs you want too. I.e rev limit launch control or whatever. Just be careful tho because the standard limit is there for a reason. Wouldn't push it up too high there's probably no room for more power as they are so you'd just be over revving for no reason. Possibly leading to damage. Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted November 10, 2013 Share Posted November 10, 2013 Just be careful tho because the standard limit is there for a reason. Wouldn't push it up too high there's probably no room for more power as they are so you'd just be over revving for no reason. Possibly leading to damage. Very true, probably no more power to be found by upping the limit to be honest and you could end up spending a lot of money for little gain. Better looking at whether there is a different gearbox with lower ratios which would help it rev faster and accelerate faster. Quote Link to comment Share on other sites More sharing options...
skitzma8 Posted November 10, 2013 Author Share Posted November 10, 2013 I'm just looking for ways to make it quicker without spending too much on the engine, as I'm going to swap it out for either a H22,B18,or a B16 soon so I just want to mess about with the little D14 atm Quote Link to comment Share on other sites More sharing options...
