Reversing lights dont work !!
Luís
Hi Guys.
So my reversing lights stoped working and i can´t figure out what is the problem.
I already check all the fuses and relay's but they are all ok.
So i check the conection that comes from the gearbox and try a direct conection but it doesn´t work.
So i test with a voltmeter and there is no power coming to the lamp connection.
So my question is if there is in the middle the fuse box to the taillght any cable connection that may be broken or disconnected?
Or if anyone of you had this problem?
And if someone knows how to solve it?
Thanks guys  :smile:
Sounds like it must be a broken wire. :(
Have you checked the bulb holder? Contacts might be dirty
It is probably that a broken wire.
I already check the bulb holder and it´s ok, not dirty  banghead.gif1
  • 1 month later...
I´ve sorted the reversing lights problem after some time spent near the engine bay but finaly it´s ok   idea.gif1
The problem was this connector it had cracked one of the connections inside, so I had to cut the cable at both ends and make a direct connection to pass out of the connector  ;)
This is the connector and the result:
Connector:
