vtismill Posted February 16, 2014 Share Posted February 16, 2014 Hi all ever since I've changed the thermostat my car has been idling high and whilst driving the car when changing gear it's like I've still got my foot on the throttle a little bit and revs up a bit, worse bit though is when coming to a standstill, when I slow down and put the clutch in the revs go up to 3k and just sit there, very frustrating, have no idea what's up with it, thought the throttle cable was sticking but there's enough slack and have put loads of wd40 on bit under bonnet and it's no different, I've cleaned iacv still no different, it's only ever when I press the clutch, I'm not sure if I've knocked something when doing thermostat or if its just coincidence, does it even when cold and warm, any ideas would be appreciated thank you Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted February 16, 2014 Share Posted February 16, 2014 What about when you first start it or have it in neutral? Quote Link to comment Share on other sites More sharing options...
vtismill Posted February 16, 2014 Author Share Posted February 16, 2014 It idles at like 2k when first started from cold which is normal I think, when cars warm it will idle normally when first started its just when I start driving it, after a hard drive its terrible pretty much every time I put clutch in revs shoot up Quote Link to comment Share on other sites More sharing options...
spudley1988 Posted February 16, 2014 Share Posted February 16, 2014 Throttle cable sticking? Quote Link to comment Share on other sites More sharing options...
Krzys Posted February 17, 2014 Share Posted February 17, 2014 I would think it was throttle body related, TPS maybe? Quote Link to comment Share on other sites More sharing options...
vtismill Posted February 20, 2014 Author Share Posted February 20, 2014 Hmm literally have no idea, it's feels like it could be cable sticking, came off a roundabout in 2nd foot flat to the floor this morn and slowed to a standstill to pull out a junction and revs just sat above 3k only goes down if I put my foot under accelerator pedal and pull it up, nothing really on it though, where would it be sticking though? How would I go about sorting it if it was that?Thanks Quote Link to comment Share on other sites More sharing options...
Krzys Posted February 20, 2014 Share Posted February 20, 2014 There should be an adjuster for the throttle cable near to the throttle body! The below isn't specifically from a Civic but should be the same principle! http://honda-tech.com/attachment.php?attachmentid=177106&stc=1&d=1291154674 Hope this helps! Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted February 20, 2014 Share Posted February 20, 2014 Check everything over. Throttle cable n all that jazz. Failing that vac leak? tps? Iacv?With thermostat being located kinda under throttle body. Have a good look make sure you haven't disturbed anything by mistake. 2 Quote Link to comment Share on other sites More sharing options...
