aeroabz Posted February 27, 2014 Share Posted February 27, 2014 I'm trying to plug my mate's universal fault code reader but connections are diff??? Quote Link to comment Share on other sites More sharing options...
simpo Posted February 27, 2014 Share Posted February 27, 2014 Don't need a code reader you want a paper clip put your hand up under glove box nearest to door and will be a 2 blue plugs bridge the 2pin blue plug with paper clip then turn your key on so lights come on the dash. Engine light will flash Slow flashes =10sFast flashes = units Read code and report back here Quote Link to comment Share on other sites More sharing options...
aeroabz Posted February 28, 2014 Author Share Posted February 28, 2014 Will this turn lights off, it's the abs and srs lights just need them off to het thru mot Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted February 28, 2014 Share Posted February 28, 2014 http://civic5.com/forum/index.php?/topic/129-how-to-reset-srs-light-if-doesnt-go-out-like-it-should/ ABS you'll need to get the code and fix the fault. Quote Link to comment Share on other sites More sharing options...
Krzys Posted February 28, 2014 Share Posted February 28, 2014 http://civic5.com/forum/index.php?/topic/129-how-to-reset-srs-light-if-doesnt-go-out-like-it-should/ ABS you'll need to get the code and fix the fault.Yes, the light means there's a fault, fix it and it'll go out! Quote Link to comment Share on other sites More sharing options...
simpo Posted February 28, 2014 Share Posted February 28, 2014 As above abs most prob need a new sensor. Srs follow guide above Quote Link to comment Share on other sites More sharing options...
