simpo Posted March 7, 2014 Share Posted March 7, 2014 Anyone know the easiest way to remove the rear window out the back doors? Quote Link to comment Share on other sites More sharing options...
10000rpm Posted March 8, 2014 Share Posted March 8, 2014 Take her pants off.Whoopz, wrong thread.Lol 😂Here's how I find it easier to doPut window down1) Pull seal out2) Remove doorcard3) Remove plastic waterproofing wrapper4) Remove the quarter glass frame/barHas a screw under the door seal at the top and one on the door skeleton5) Lower window until you can see the two 10mm bolts holding glass on to rail, whilst holding the glass remove the 10mm bolts.6) Pull the glass out7) Now the quarter glass can be pulled out to.fit in reverse, DON'T over tighten the two 10mm bolts, just firm.spray wd40 or gt85 down the tracks and slide the rubber in last it will go.Been a while since I have done one, I think thats everythingHope that helps 4 Quote Link to comment Share on other sites More sharing options...
simpo Posted March 8, 2014 Author Share Posted March 8, 2014 Yeah cheers for that mate was hoping there was away with out taking rubber out lol! Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted March 9, 2014 Share Posted March 9, 2014 It is possible to do without removing other window but i suggest doing it the way Naz suggests.. But this is the other method from my build thread.. Got this today from my mechanic/rover breaker £5.00 Lovely.. A Bit Of A Clean Later So off to work fitting it.... Removed door card and was told by my mechanic it is possible to fit without removing the main window so this is how i did it... Pictures are after removing but make it clearer to see how to Remove Window Winder.. Pic shows clip you need to shift to pull it off You Need A Medium Sized Cross Head Screwdriver Then The Door Handle A Smaller Cross Head Screwdriver And Then Slide To The Left Carefully Here You See How It Was Mounted And The Rear Of The Handle Showing The Clips Undo The Two 10mm Bolts To Release The Centre Bar Pull Back The Rubber Seal At Top To Reveal Hiiden 8mm Nut Now Push Centre Bar All The Way To Bottom Of Door (its tight but it does go) Bottom Of Centre Bar Now push The Weather Strip As Indicated In Pic Or Centre Bar Will Still Be In The Way (be gentle not to break the clips i did not thankfully) Then pull out old broken window and ding it LOL It is awkward to get the new one in requires a bit of fiddling and then pulling the rubber over the inside part of the door but it does go I Would Suggest You Heat The Rubber Seal Of The New Window With A Hair Dryer Before Fitting. (i did not as it was raining and i needed to do it in a hurry so i messed my rubber up visually a little bit but still water tight) Ensure that the centre bar is still on the window inside the door and facing the correct way at the top when fitting new window Then refit window seal at top slide the centre bar back up into place and refit in reverse.. And You Get This Look At The Mess Poor Little Car Twenty Mins Later However Although this method worked and had i used a hairdryer i prob would not of made the inside rubber look untidy if you have time i would remove the main window and then it just slides into place 2 Quote Link to comment Share on other sites More sharing options...
simpo Posted March 9, 2014 Author Share Posted March 9, 2014 Cheers mate but all done now! I'm a pro at it now as took it out again today as forgot to put tinted small side window in lol Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted March 9, 2014 Share Posted March 9, 2014 LOL the professionals .. Good work Quote Link to comment Share on other sites More sharing options...
3gdean Posted April 5, 2014 Share Posted April 5, 2014 Thats rapid hair drying power right there... nice work! 1 Quote Link to comment Share on other sites More sharing options...
Guest Adam Rafique Posted April 21, 2014 Share Posted April 21, 2014 a lot of work for a little piece of glass! lol Quote Link to comment Share on other sites More sharing options...
simpo Posted April 21, 2014 Author Share Posted April 21, 2014 Not really mate don't take that long Quote Link to comment Share on other sites More sharing options...
Krzys Posted April 21, 2014 Share Posted April 21, 2014 a lot of work for a little piece of glass! lolDepends if you want a window there or not! Quote Link to comment Share on other sites More sharing options...
