Camber setup??
NIKH25
  On 4/27/2014 at 8:01 PM, 93 Accord said:
Glad to help!
Id start with that, if you want to keep how the top of the tyre sits in relation to the wing, maybe add a 3mm spacer.
Having the adjustability is handy, but remember the toe will change too. You will need to do the tracking every time you make a change.
Cheers, I like the way the tyres sit right now so that's fine.
Yes, I probably won't be lifting it up and down to be honest as I've got it right where I want it now.
I'm holding off on the alignment until I've done fettling and fitting adjustable camber arms so hopefully only have to do it once for the time being!
