Camber setup??
NIKH25
I went to get a 4 wheel alignment done this afternoon, unfortunately their ramp was s**gged and wouldn't lock in place so the car was leaning to one side so it couldn't be done.
However the chap there has asked me to seek advice as to what camber I should be running on the rear, it looks like the front will be around 2 deg. Anybody got any suggestions?
Cheers guys. :)
Have you got camber adjusters? Don't think they adjust without.
I'd say just match the front
http://yospeed.com/wheel-alignment-explained-camber-caster-toe/
I don't want to match the front, it's not recommended as it will upset the balance.
im running about 4 degrees at the minute ;)
Yes, well you need that just to get them under the arches.
ha ha i know ;) will be needing more camber soon i recon ;)
Mines running 3.5 degs. Which is probably too much. Want it to around the fronts, the guy that did mine (honda mentalist & expert) said he'd like to get the rears to about 1.8-2.0 - http://www.performance-autoworks.co.uk/index.php
Try and ask your bloke to dial in a little toe in on the rear too. Assists in turn in. Too much though and the rear will become a little restless.
Cheers, so I probably want a bit less maybe 1.2-1.5 if I have 2.0 on the front?
From his logic mate yes. Plus a little 0.5 degree toe in and she should handle a treat!
