service/ jumper plug
camoturd
Well I have done it now it showed a 16 fault code I know it do do with 5 he abs sensor on my rear right wheel what would be the fix for it please
Yep, if it's showing a sensor fault, replacement is the only option unfortunately, try one 10000rpm on here or ask on the facebook page.
Apparently they're about £250 new from Honda. :o
If he's doing it on the 2 pin like he said in first post it won't be a abs sensor as that's on the 5pin! Think 16 is fuel injectors
Well spotted.
Is it the CEL that's lit up or the ABS light?
If there's an ABS fault the ABS light will stay on.
It is a 6 slot one not 2 slot and it came up 16 but now has turned off completely which is something I wasn't expecting at all
Don't worry about it then. Sounds like you've reset it.  :)
