vtec2011 Posted May 18, 2014 Share Posted May 18, 2014 I was installing my Pioneer headunit into the Aerodeck and it has no power going to it? It worked in my MB3 and it worked in the Fiesta. The original headunit worked in the Aerodeck too but not the Pioneer. I plugged the Pioneer headunit back into the Fiesta again and it works fine, so the headunit is ok. I then used a electrical screwdriver to check if power is going through the live wire (red ignition wire) and the earth wire (black) from the Aerodeck's wiring loom and the headunit harness, power is going through them. I have even checked the headunit fuse and the fuse in the car itself. I shouldn't need to because the original headunit for the Aerodeck still works. The final thing I have done is hook the headunit directly to the battery, still no power... So plugged it into the Fiesta again, the headunit powers on... So now I'm stuck... Can anyone shed some light? Much appreciated, cheers Quote Link to comment Share on other sites More sharing options...
simpo Posted May 18, 2014 Share Posted May 18, 2014 When you put it on the battery did you use red and black or red yellow and black?@vtec2011 Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted May 18, 2014 Author Share Posted May 18, 2014 Just red and black. Yellow is just a memory wire I think Quote Link to comment Share on other sites More sharing options...
simpo Posted May 18, 2014 Share Posted May 18, 2014 Try yellow red on live and black on neg bet it works 1 Quote Link to comment Share on other sites More sharing options...
Krzys Posted May 18, 2014 Share Posted May 18, 2014 I was going to suggest the same as Simpo. Hope it works, strange one that if it doesn't! Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted May 18, 2014 Author Share Posted May 18, 2014 I will give it a go now. Cheers Simpo Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted May 18, 2014 Author Share Posted May 18, 2014 Joined the red and yellow wires together and now have power!! Thankyou, it was really doing my head-in earlier 1 Quote Link to comment Share on other sites More sharing options...
simpo Posted May 18, 2014 Share Posted May 18, 2014 Next prob is I would say it's your loom from head unit to main loom. Your lives must not be lining up Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted May 18, 2014 Author Share Posted May 18, 2014 Huh? Why has it posted this thread twice? Haha Ford disease... All sorted now, just wired a couple wires together and now have power. Thanks to Simpo 1 Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted May 18, 2014 Author Share Posted May 18, 2014 I will have a proper look another time as the f**king headunit won't sit in the dash now. I remember on the MB3 I have to cut out a piece of plastic at the back Quote Link to comment Share on other sites More sharing options...
