Dougie Posted May 30, 2014 Share Posted May 30, 2014 I've noticed recently that if I throw the car into a tight corner the handbrake light comes on..... anyone else seen this? It's possible that it's caused by one of my rear calipers being a bit dodgy but not sure Quote Link to comment Share on other sites More sharing options...
Chandler Posted May 30, 2014 Share Posted May 30, 2014 i had this dont worry mate, i had it while going along normally aswel, sticky sensor i think... when you next go for a drive, on a quiet road yank the handbrake up a few times and see if that does it?not fast obviously ha ha, if not try and find the sensor and spray a little WD-40 on it and pull the handbrake up a few times to loosen, hope this helps Quote Link to comment Share on other sites More sharing options...
Dougie Posted May 31, 2014 Author Share Posted May 31, 2014 cool thanks man, ill probably just ignore it for now, completely refurbing my brakes over the summer and right now the hand brake bearly works anyway so its not really a problem was just slightly surprised that the light was comming on when i really stick it into a bend Quote Link to comment Share on other sites More sharing options...
3gdean Posted May 31, 2014 Share Posted May 31, 2014 check you brake fluid level sensor aswell Quote Link to comment Share on other sites More sharing options...
marv Posted June 2, 2014 Share Posted June 2, 2014 check you brake fluid level sensor aswellThis! Quote Link to comment Share on other sites More sharing options...
