Guest martin Posted July 3, 2014 Share Posted July 3, 2014 Had all bushes and ball joints checked - all goodLeft front calliper is sticking slightly but can easily be moved by hand and mechanic advises it shouldn't cause a problem taking into account the weight of the car. Under acceleration the car pulls right, lay off and it goes straight, also goes straight under braking. I'm out of ideas, help please! Quote Link to comment Share on other sites More sharing options...
dr_broon Posted July 3, 2014 Share Posted July 3, 2014 I had the same and it turned out to be the tyres... Luckily just uneven pressures for me. If posted on here about it and tyres were suggested to me, and that's what it was. Hope it's that easy for you as well Quote Link to comment Share on other sites More sharing options...
Guest martin Posted July 3, 2014 Share Posted July 3, 2014 The mechanic checked that, and unfortunately tyre pressure was all good Quote Link to comment Share on other sites More sharing options...
dr_broon Posted July 3, 2014 Share Posted July 3, 2014 I'm sure that someone suggested miss matched tyres as a possible cause as well - are both front tyres the same? Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 3, 2014 Share Posted July 3, 2014 Check tyres are the same make and size and if that checks out then check the tracking. Quote Link to comment Share on other sites More sharing options...
Guest martin Posted July 3, 2014 Share Posted July 3, 2014 Tracking it is tomorrow then guys - thanks for all the help Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 3, 2014 Share Posted July 3, 2014 Hope that sorts it mate! Quote Link to comment Share on other sites More sharing options...
Grant Posted July 4, 2014 Share Posted July 4, 2014 X2 on tracking and uneven tyres ! I never ever run different tyres cross axle ... Back & front is too bad .. But never side to side .. Geo is most likely the cause .. Quote Link to comment Share on other sites More sharing options...
10000rpm Posted September 3, 2014 Share Posted September 3, 2014 Check your torque mounts too mate, had a couple like this. Quote Link to comment Share on other sites More sharing options...
Mr Brown Posted September 4, 2014 Share Posted September 4, 2014 Did you get your tracking checked mate was it the issue Quote Link to comment Share on other sites More sharing options...
