mark11 Posted August 26, 2014 Share Posted August 26, 2014 My ABS light is on, just wondering best way of finding out which sensor has gone.ive done a search on here to find out where the plug is but where do i find the bliking codes so i know which ones gone ive got this which someone gave me years ago and they said it was a code reader for Jap cars, but ive never used it so dont know if itd work Quote Link to comment Share on other sites More sharing options...
Roj Posted August 26, 2014 Share Posted August 26, 2014 You'll find the blinking code by looking at your ABS light on the dashboard. You probably found this already but here it is in case you haven't: http://civic5.com/forum/index.php/topic/21-diagnosing-abs-probs-and-other-fault-codes/ Quote Link to comment Share on other sites More sharing options...
powerofdreams Posted August 27, 2014 Share Posted August 27, 2014 I found it easier just to Jack car up. Disconnect sensor and put a multi meter across the sensor and spin the wheel. The valve should fluctuate. Repeat on all 4 wheels. The sensor that is fault will b the one that doesn't . Quote Link to comment Share on other sites More sharing options...
Krzys Posted August 27, 2014 Share Posted August 27, 2014 On 8/27/2014 at 12:06 AM, powerofdreams said: I found it easier just to Jack car up. Disconnect sensor and put a multi meter across the sensor and spin the wheel. The valve should fluctuate. Repeat on all 4 wheels. The sensor that is fault will b the one that doesn't .Sounds simple enough! Quote Link to comment Share on other sites More sharing options...
mark11 Posted August 27, 2014 Author Share Posted August 27, 2014 so if i bridge it like says in the link my abs light will flash but the link on the other page about codes does not work ? cheers Quote Link to comment Share on other sites More sharing options...
mark11 Posted August 27, 2014 Author Share Posted August 27, 2014 do u put the multi meter across the conector or the sensor Quote Link to comment Share on other sites More sharing options...
powerofdreams Posted August 28, 2014 Share Posted August 28, 2014 The sensor. Quote Link to comment Share on other sites More sharing options...
simpo Posted August 28, 2014 Share Posted August 28, 2014 Just bridge the pin takes 2 secs why jack the car up when there is a plug there to tell you Quote Link to comment Share on other sites More sharing options...
mark11 Posted August 28, 2014 Author Share Posted August 28, 2014 so if i bridge the pin im assuming the abs light will flash.Im guseeing these are the codes (11) (13) (15 (17) will it do a long one for 10 and then 7 flashes to = 17.does anyone know how to decipher the flashes if it is the sensor does anyone know best place as cant find one on ebay and local car factors dont do them and im guessing honda will be through the roof. im hoping it just needs cleaning up Quote Link to comment Share on other sites More sharing options...
Krzys Posted August 28, 2014 Share Posted August 28, 2014 On 8/26/2014 at 8:33 PM, Roj said: You'll find the blinking code by looking at your ABS light on the dashboard. You probably found this already but here it is in case you haven't: http://civic5.com/forum/index.php/topic/21-diagnosing-abs-probs-and-other-fault-codes/ On 8/28/2014 at 7:29 AM, mark11 said: so if i bridge the pin im assuming the abs light will flash.Im guseeing these are the codes (11) (13) (15 (17) will it do a long one for 10 and then 7 flashes to = 17.does anyone know how to decipher the flashes if it is the sensor does anyone know best place as cant find one on ebay and local car factors dont do them and im guessing honda will be through the roof. im hoping it just needs cleaning upCodes in the link Roj posted. Those four point to all four sensors, quite a feat if that's the case! Quote Link to comment Share on other sites More sharing options...
