Help!!!!!! MY ABS Light on
mark11
My ABS light is on, just wondering best way of finding out which sensor has gone.
ive done a search on here to find out where the plug is but where do i find the bliking codes so i know which ones gone
ive got this which someone gave me years ago and they said it was a code reader for Jap cars, but ive never used it so dont know if itd work
I found it easier just to Jack car up. Disconnect sensor and put a multi meter across the sensor and spin the wheel. The valve should fluctuate. Repeat on all 4 wheels. The sensor that is fault will b the one that doesn't .
Sounds simple enough!
so if i bridge the pin im assuming the abs light will flash.
Im guseeing these are the codes (11) (13) (15 (17) will it do a long one for 10 and then 7 flashes to = 17.
does anyone know how to decipher the flashes
if it is the sensor does anyone know best place as cant find one on ebay and local car factors dont do them and im guessing honda will be through the roof.
im hoping it just needs cleaning up
You'll find the blinking code by looking at your ABS light on the dashboard. :)
You probably found this already but here it is in case you haven't: http://civic5.com/forum/index.php/topic/21-diagnosing-abs-probs-and-other-fault-codes/
Codes in the link Roj posted.
Those four point to all four sensors, quite a feat if that's the case!
