GB. Posted March 8, 2010 Share Posted March 8, 2010 My vti seems to have a low pedal, changes gear lovely, just a low pedal Now my first thoughts are dodgy slave cylinder , is this a common problem and if it is the slave can I use my ek4 cylinder?GB Link to comment Share on other sites More sharing options...
civicturbo79 Posted March 8, 2010 Share Posted March 8, 2010 What do you mean by low the pedel sides low or the bitting point is low to the floor . Rich. Link to comment Share on other sites More sharing options...
stoocake Posted March 9, 2010 Share Posted March 9, 2010 Also, check for leaks around either side of the firewall where the cylinder passes through...peel back the carpet a little in the drivers footwell and look for either moisture, or signs of bubbling/flaking paint. Turns out mine was leaking, didn't notice until I removed my carpet, but glad I caught it before it was too late and actually saw any more symptoms. Link to comment Share on other sites More sharing options...
KiNK43 Posted March 20, 2010 Share Posted March 20, 2010 my clutch has always bit low, and i have just literally found that the master cylinder???? at the peadal is leaking. just looked through forum to see if any posts about it and found this.seems to be a common problem. Link to comment Share on other sites More sharing options...
GB. Posted March 24, 2010 Author Share Posted March 24, 2010 Biting low,but no adverse affect on performance though. Link to comment Share on other sites More sharing options...
KiNK43 Posted March 24, 2010 Share Posted March 24, 2010 basically. yeah.gears engage fine. just get a shaky leg at traffic lights tryin to keep the clutch disengaged!ordered a new master cylinder.any info on how to bleed would be useful? Link to comment Share on other sites More sharing options...
stubrun Posted March 25, 2010 Share Posted March 25, 2010 it is bled at the slave cylinder mounted on the gearbox. you will see a bleed nipple on it. Link to comment Share on other sites More sharing options...
KiNK43 Posted October 24, 2010 Share Posted October 24, 2010 How normal is this low bite problem? I have today got around to fitting new master cylinder (courtesy of beastgtir) installed, pumped tons of fluid through and kept topping up. Closed nipple with pedal to floor. At first couldnt disengage clutch at all but kept pumpingPedal until finally it disengaged. Ive checkf for leaks and reservoir full, but still the bite point is still mm's from the floor. Why is this? I was hoping it would be normal so I wonder if ive missed something. Any help appreciated. Jake Link to comment Share on other sites More sharing options...
simpo Posted October 24, 2010 Share Posted October 24, 2010 my vtis had a very low bite point all i can say is dont get uprated clutch because you will have to stand up at traffic lights to hold the clutch in lol Link to comment Share on other sites More sharing options...
KiNK43 Posted October 24, 2010 Share Posted October 24, 2010 haha, i was getting a shaky leg already at junctions. the new cylinder is much lighter at least.soooo am i to assume that this is normal for some civics??or is there anyway i can adjust it???silly question as its very straight forward system i know.but i did notice the thread on the piston itself, do i touch this? Link to comment Share on other sites More sharing options...
