15" et 38 alloys on a lowered deck
dreadi
No idea, I don't really wonna get mega budgets but they will have to be cheap ones. I did consider just keep standards for now but finding nice 4x114 alloys is quite hard and the 15s I'm looking at are 250 with tyres which is about 100 more then just buying 4 tyres if buying t1rs.
And saving is gonna hard as my little one is due in a few months !
That's the ones. I know they do! :D my others are oz volcanos sprayed black on the lip and gold on the spokes. And I'm really running out of time to make my mind up before my free MOT retest runs out!
Would 16s be more a problem with then being bigger wheels? The et difference is only 2mm so I suppose that's not but would the diameter cause more of an issue?
I really recommend willtheyfit.com. Here are 2 setups that i've had in the past, 15" and 16" compared that will fit and wont rub: http://www.willtheyfit.com/index.php?width=195&aspect=55&diameter=15&wheelwidth=7&offset=37&width2=205&aspect2=45&diameter2=16&wheelwidth2=7&offset2=40#content
The amount of drop won't matter (unless you go crazy low!), atleast on these tyre/wheel combos, because the lower you go the more natural camber you'll get (unless you've installed and adjusted camber kits) and the tyres will tuck in to the wheel wells. Just type your planned wheel & tyre combo on to the "new setup" section and see how much difference will it make.
I'm low enough to scrap the exhuast on every speed bump I go near! :D
So I really nees to get these tyres ordered tonight. I'm think 195/45/16 as there's plenty of tyre options at this size. Any reason why I should go for a different size?
