  • 0
Coolant leaking plus temperature going up and down
ammarbm
I had a full service done on Saturday.. Also changed the thermostat and anti freeze as my car was taking too long to warm up.. One thing I noticed after the service was that the reservoir bottle was over filled with coolant.. The car drove fine and was warming up perfectly but I drive a bit far last night and drove upto 60mph.. When I got home I could see some smoke coming out by the headlights.. Parked up and looked underneath and the coolant was running down the manifold and dripping by there and that was causing smoke.. So I checked the coolant level in the bottle this morning before leaving for work and it was just below Max so it didn't lose too much.. I topped it up with water so it was on the Max level.. But when I was driving to work and went upto 60 the temperature started rising and went past the half way.. When I slowed down to 30 to 40 it would come back down to normal.. Needle kept moving between normal to over half way.. I can't go back to the mechanic till Friday as I am working 12 hours every day to then.. Any suggestion please and also is it ok to drive the car at slow speed like this as I need to drive to get to work.. It's 4 to 5 miles from my house
  • 0
Yup!
Just going off the ones I've dealt with personally:
Belts - Mitsuboshi (Although I went for a Gates Racing belt myself)
Tensioner - Koyo
Water pump - NPW
There's bound to be more than one supplier that Honda deals with for their parts, so it's worth looking around when looking for parts. :)
I haven't found that NPW water pump anywhere but the one on japserviceparts is from GMB
  • 0
I got NPW from JP4mance. I see good reviews for GMB on Google.
Answer this question...
