- Yesterday
thanks Simon ð yes looking at the rubber parts, found the parts for the top e.g. Items 9 & 6 , struggling with the bump stop ATM, Item 11, PN 51722-st3-e01. -
Diagram and parts numbers all here dude https://www.parts-honda.uk/honda-cars/CIVIC-AERODECK/1999/VTI/STEERING-BRAKE-SUSPENSION/FRONT-SHOCK-ABSORBER/17S1E01/B__2800/4/8427 Rubber mounts are probably worth doing Don't forget mgzs / rover compatibility for suspension if you don't have any joy using honda part numbers
about to replace front shocks on my aerodeck 1.8vti. looking at the haynes manual, there appear to be quite a few parts in the strut assembly, was hoping to retain as much as poss, but are any of these likely to need replacing also, as well as the damper ? will inspect before replacement and replace any that are not re-usable, but would be useful to know in advance any parts that are likely to be shot given the age and mileage. so I can get these on order, or at least locate a source for a possible replacement. I have had both struts out before to change the top BJs, all appeared ok then, but could be a different story when I disassemble the strut.... I guess a honda diagram of the strut assembly plus part numbers would be useful, will see if I can find online, unless someone has to hand ? cheers for reading folks
- Last week
Sounds like a frustrating few hours in the heat there. Hate stuff like that. - Earlier
A day of ups and downs working on the MB2 today Managed to do the last few jobs to get the engine ready to install. However, try as we might we just could not get the engine to go into the mounts, despite everything going ok. After about 4 hours of swearing, hoisting the engine up and down, and tilting it evey which way we could think of, it would just not go into the mounts and the aux belt and pulleys kept getting snagged After giving up and looking on the internet for advice I found that the right hand (drivers side) engine mount supplied was the wrong one. Our looks like this with the "cradle" coming out the side of the mount But it's supposed to look like this with the cradle on top! Because the mount fits to the car and the rest of the kit is correct we didn't realise for an embarassingly long time. Never mind ... I will complain and hope to get supplied the correct part as soon as possible For now this is as far as we've got ... So close but yet so far ... -
Plastic should be lighter than aluminium also #racecar haha ðĪŠ
Can't wait to get it in the road and go adventuring ðïļ
Some of the rear seat configurations The middle row also flip round to face backwards.. Pretty clever setup ð
Yes, it's surprisingly lively when you give it since beans, but it lulls you into pottering about being eco ð The new wagon isn't really a wagon at all... It's a k20 (the slow one) It's an auto It's big It's got 8 seats It's from Japan..... It's a stepwagon! Needs some tlc, as its been getting used as a works van by the import company we got it off, and the crazy fibre glass bumper needs fixing from being smashed on an uneven road (probably with the air suspension too low), and the massive rear spoiler needs refitting (maybe...), but it generally needs a really good clean. The paint from the body kit also peeled off when they've took their stickers off.
