Krzys Posted July 1, 2015 Share Posted July 1, 2015 http://civic5.com/forum/topic/9769-ive-overfilled-coolant-tank/#entry246979 Quote Link to comment Share on other sites More sharing options...
onejdmcivic1984 Posted July 1, 2015 Author Share Posted July 1, 2015 Kryzs - didn't ignore the advice but had a D16Y8 installed and thought that would sort it lolNext I will get thermostat checked Quote Link to comment Share on other sites More sharing options...
onejdmcivic1984 Posted July 1, 2015 Author Share Posted July 1, 2015 Well he's checked the power going to the fan with a electric thing (not sure what's it called but plugged to battery terminals) and it moved so its nor a broken radiator fan. Topped up the expansion bottle earlier too. So its something electrical on the radiator fan of thermostat - whatever it is its giving me headaches Quote Link to comment Share on other sites More sharing options...
simpo Posted July 1, 2015 Share Posted July 1, 2015 Just change the thermostat that should of been the first thing to do! It can be a bitch to bleed so make sure you do it properly 1 Quote Link to comment Share on other sites More sharing options...
Chandler Posted July 2, 2015 Share Posted July 2, 2015 is the bottom hose getting hot? and is the top hose really hot?if so its thermostat Quote Link to comment Share on other sites More sharing options...
Dexter Posted July 2, 2015 Share Posted July 2, 2015 I had occasional overheating issues for years and finally solved it by replacing the radiator. Visually it was fine but in the end it was either clogged up or broken. Anyways no problems after that. But it might be worth it to use radiator flush etc. on your system. Quote Link to comment Share on other sites More sharing options...
