Calling MOT testers
fyfie5
The other Phil is in a better position to answer than me, (not done an mot test since 2013), but from what I remember it may not even be advised on. I think it's only abs and Srs lamps that can fail an mot test.
Will fail as the MIL light will put the ECU into a safe mode on obd2<or closed loop><or may be other way round>
ie: a rich mixture and above the limit for a MOT <as the ecu will loose the learn capability >
Depends why its on also
so why is it on ??
PS am not a MOT tester
