marv Posted August 11, 2016 Share Posted August 11, 2016 Hi guys, my deck had the classic heater fault only working on 3 and 4. Coming back from work this morning it's now just stopped working altogether. Would it just be the resistor that needs replaced? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
0 kern Posted August 11, 2016 Share Posted August 11, 2016 I would start with replacing the resistor 1st as its only a couple of quid for a new one! Quote Link to comment Share on other sites More sharing options...
0 dr_broon Posted August 11, 2016 Share Posted August 11, 2016 I agree, but could be that the motor has gone. Quote Link to comment Share on other sites More sharing options...
0 Chandler Posted August 11, 2016 Share Posted August 11, 2016 as above. could be the motor aswel Quote Link to comment Share on other sites More sharing options...
0 Guest Luis Posted September 1, 2016 Share Posted September 1, 2016 hello, you can test the fan by plugin 12v on cable conector... if runs its ok, and replace the relay, or if like open the fuse box and change the replay for the next on the fuxe box and run the engine... for best confidence test, plug 12v on wires connection abive the fan (unplug the wire fan cable the plug with 12v battery on that wires) if it spins theres ok... thats all, i hope it helps. best regards Quote Link to comment Share on other sites More sharing options...
0 Guest Ross Aerodeck Posted November 5, 2016 Share Posted November 5, 2016 The resistor behind the glove box will be the problem. I got one from a Jap 3 door civic and noticed it's made with thicker metal than the British made ones. stuck that in and it's been fine ever since. Quote Link to comment Share on other sites More sharing options...
Question
marv
5 answers to this question
