  • 0
1.6 Aerodeck not starting
Vladbulin
Hi there,
Went to start my car this morning and it just wouldn't start.
Engine is not cranking at all.
All the dashlights are coming on as they should and the immobiliser light dissapears on position 2 as it should
Checked all the fuses are fine, even replaced the ignition 50A one
Also tried to bump start the car but had no luck there
Any ideas?
5 answers to this question
  • 0
Not cranking could mean battery? Do the ignition lights go out when you try to start it? Does it just click? It could also be the starter that's at fault mate.
  • 0
All sorted out guys, was just engine ground
Tried hot wiring the starter and it wasn't even getting a spark, so grounded it directly to the battery with a jump lead to see if it was the problem and sure enough it just fired up
Cheers for the input
Answer this question...
