  • 0
Aerodeck mc2 vti drifting in Lane!
Ashley meekings
Hi all, again I'm normally good at problem solving on cars as qualified mechanic myself.
My aerodeck has been neglected for a while as had career change an it's took me while to get onto better money so has a few issues I'm slowly sorting
I had two new front tyres an tracking done. Now when cruising sort of 50mph upwards in 5th gear on the dually. If I slowly press the throttle, but making sure the steering is straight, the car effectively crabs over to the right of the lane, not I'm a dangerous snatchy way, but a smooth but definatele glide straight over, an when I let off the throttle it them returns to the left of the lane.
The cars issues which could be related are as follows
Both track rod ends worn but not split, I have 1 lower ball joint worn but not split
Both upper ball joints need replacing
And I have a split drive shaft oil seal due to recent clutch change.
My front pads are pretty much finished, have ordered more but they may be shifting. Could any of those issues be causing the car to drift/glide like 4 or 5 foot to the right an left when the steering is dead straight? Scratching my head
  • 0
Just another point. I had a pair of cheapo matching brand tyres on the front of my mc2. Even after wheel alignment it would pull. Swapped front to back and I now have 2 old Michelins on the front and the problem has gone away... different quality between 2 tyres of the same brand may be a cause.
Answer this question...
