Antoniyo1593 Posted March 19, 2021 Share Posted March 19, 2021 Hi guys i need help with my aerodeck! So my deck is fitted with headlight washers, my dimmer switch is f**ked so had to short the black and red wires. But then my headlight washers switches my rear foglights. Rear foglight switch doesn't do anything. Please help! 1 Quote Link to comment Share on other sites More sharing options...
Dave Posted March 19, 2021 Share Posted March 19, 2021 Mate if you need a dimmer switch I should have plenty of those in the garage. You want me to send one down to you, so you can put the wiring back to normal? Saves trying to work out why its doing that with the rear foglights? If its the headlight washer switch, think I've got those in stock too. 1 Quote Link to comment Share on other sites More sharing options...
Antoniyo1593 Posted March 20, 2021 Author Share Posted March 20, 2021 Thanks man that would be great! I'll be needing the dimmer switch with the headlight washer switch with it 2 Quote Link to comment Share on other sites More sharing options...
Dave Posted March 20, 2021 Share Posted March 20, 2021 3 hours ago, Antoniyo1593 said: Thanks man that would be great! I'll be needing the dimmer switch with the headlight washer switch with it Should have those, I'm off to the garage now so will check and get back to you mate 1 Quote Link to comment Share on other sites More sharing options...
Dave Posted March 20, 2021 Share Posted March 20, 2021 @Antoniyo1593 Got 1 here for you mate, tested it in DD and working fine. You want to pm me your details and I'll get it posted to you. 1 Quote Link to comment Share on other sites More sharing options...
