Antoniyo1593 Posted March 26, 2021 Share Posted March 26, 2021 Hi guys! Just got my oem bbig foglights.. my deck didn't have any so have to change the switch. But one set of wires was cutout can you guys help me find out where does the cut wires go? And will i need a separate foglight relay or controller? Quote Link to comment Share on other sites More sharing options...
Dave Posted March 26, 2021 Share Posted March 26, 2021 Hi Tony, There are 3 separate harnesses for the OEM foglights. One in the dashfrom the switch to fusebox/harness number 2, Harness number 2 which goes from bulkhead to just behind drivers side headlight, then harness 3 which goes from behind headlight to the fogs themselves. there is a relay you will also need which is fitted either on the interior fusebox or near it, can't quite remember which! DD had them fitted by Honda at the dealership after we bought her. I did however retro fit oem fogs to my first Civic M, my MA8, so thats how I found out what is needed. It is a bit of a pain to fit, but is worth it for that OEM look. Quote Link to comment Share on other sites More sharing options...
