Piston and rod question?
Psbdeck
Hey all,
A question I'm not just 100% sure on and maybe somebody can help.
I got my hands on a set of pistons and rods for the vti deck. Now on closer inspection it appears I have got type r rods and pistons.
So the question is, can I put these straight into the standard c4? Mixed answers online. Some saying cams and a map are needed.
Or would I be able just to put them straight in with no real.dramas?
Many thanks all.
FFS Tech | B-series Piston Check (ff-squad.com)
gsr has little more CR than b18c4 <10:1 ?>so be about this below and would be better without the snail inlet  manifold and p28 ecu,but try it maybe ok with 98ron gas,you need to know what you have also..
P73 JDM pistons in B18C w/GSR head CR=11.3-4ish
P73 US pistons in B18C w/GSR head CR=10.8-9ish
Edited by noodels
@noodelsam I remembering that UK 99 spec is the same as jdm as well?
