MC2wo Posted December 15, 2021 Share Posted December 15, 2021 Just purchased a k20 aerodeck, when you start it from cold you have to prime the fuel pump twice as its still got the standard pump in. So when you key on, it doesn't prime the fuel enough so means it cranks over for longer, but if your key in and off twice, then it builds enough. Am I right in thinking king if I fit a walbro 255 pump then it'll be able to prime enough on the first key? As its a bigger, more power pump Thanks in advance Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted December 17, 2021 Share Posted December 17, 2021 Maybe however. what software are you using? On hondata you can set the pump prime time. So could up it to 3 or 4 seconds. Quote Link to comment Share on other sites More sharing options...
MC2wo Posted December 17, 2021 Author Share Posted December 17, 2021 I'm pretty sure it's on hondavert... I need to sit down and go through everything I've got as I keep forgetting stuff lol But I've ordered a walbro 255 now, even if its not that, it'll be an improved over the 20 year old d16 pump 1 Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted December 17, 2021 Share Posted December 17, 2021 If it is hondavert then again should be able to plug it in and adjust prime time. As you can use k manager with hondavert. Just download the recommended version from hondavert website. 1 Quote Link to comment Share on other sites More sharing options...
MC2wo Posted December 18, 2021 Author Share Posted December 18, 2021 Oh right sound... Nice one Quote Link to comment Share on other sites More sharing options...
