Aerodeck k20 fuel prime
MC2wo
Just purchased a k20 aerodeck, when you start it from cold you have to prime the fuel pump twice as its still got the standard pump in. So when you key on, it doesn't prime the fuel enough so means it cranks over for longer, but if your key in and off twice, then it builds enough.
Am I right in thinking king if I fit a walbro 255 pump then it'll be able to prime enough on the first key? As its a bigger, more power pump
Thanks in advance
I'm pretty sure it's on hondavert... I need to sit down and go through everything I've got as I keep forgetting stuff lol
But I've ordered a walbro 255 now, even if its not that, it'll be an improved over the 20 year old d16 pump
