edfiasco Posted October 28, 2010 Share Posted October 28, 2010 I have one of these ready to go on, anyone know the exact bolts i need? many thanks.. Link to comment Share on other sites More sharing options...
stubrun Posted October 29, 2010 Share Posted October 29, 2010 james posted already mate4x 8mm x 18mm2x 10mm x 60mm Link to comment Share on other sites More sharing options...
noodels Posted October 29, 2010 Share Posted October 29, 2010 thread pitch might be handy!1.25 for the 8mmand seem 2 be going for £30 1"£££$££"!! Link to comment Share on other sites More sharing options...
muggs Posted October 30, 2010 Share Posted October 30, 2010 hiim getting confused here, ive had this bar for over a month because im too lazy to find the correct bolts, ive been to focus and b&q they have the 10mm bolts but not at 60mm length (dont want to get longer and cut them down) anyway, one guy here is saying its a straight swap no bolts needed just use the ones that are already holding the original arb in place, as long as its a mb6 its a straight swap with nothing needed, now further down the thread theres a guy asking what bolt sizes for the swap, his profile says he has a mb6 and then he gets a reply telling him the bolts sizes??so please once and for all i have a vtis and the rover arb from ebay with drop links. can i re-use the bolts that are holding my honda arb onto the car.you know what i think im going to need the 10x60mm bolts only, because from looking under the car, the bolt that holds the lower part of the drop link to the lower control arm could actually be part of the droplink, i can see the threaded end and the nut but the other end it not visible. Link to comment Share on other sites More sharing options...
james Posted October 30, 2010 Share Posted October 30, 2010 yea whats the right bolt, then we can write it into the how to??? Link to comment Share on other sites More sharing options...
noodels Posted October 30, 2010 Share Posted October 30, 2010 mb6 you can use same bolt to chassis but need 10mm 50-60 mm +nuts mc2 need 8mm 1.25 pitch 15-20mm long+the abovemb6 uses drop links so cannot use existing bolts.and need new onesmc2 has no arb so all fixing are needed there is topic on here already!! Link to comment Share on other sites More sharing options...
james Posted October 30, 2010 Share Posted October 30, 2010 http://cgi.ebay.co.uk/M10-x-70-High-Ten ... 19bc0478dai sent a ebay member a message to see if i can get these boltsso link to lower arm..... m10 x 60L brakets....... m8 x 18 nylock nuts ....m10thats my list Link to comment Share on other sites More sharing options...
noodels Posted October 31, 2010 Share Posted October 31, 2010 need washers as well+sping washers 4 of each 8mm for chassis ones bloody expensive!!!! Link to comment Share on other sites More sharing options...
matrix1 Posted November 1, 2010 Share Posted November 1, 2010 Hi All,New on here, so apologies if I make any mistakes & so forth....Regarding the MGZS Anti roll bar ( which I have just ordered ), just want to confirm that I will require some extra bolts and nuts etc to change the anti roll bar on my mb6 hatch, which consist of the following:1,M10 * 60mm bolts QTY ?2,M8 * 60mm Bolts QTY ?3,M10 Nylon lock nuts4 M8 Nylon Lock nuts5, Washers6 Spring WashersAre the nuts and bolts from Screwfix okay to use?If not, where is the best place to get these from?Once again apologies if I've used the incorrect terms or anything as I'm a complete novice at this. Link to comment Share on other sites More sharing options...
stoatman Posted November 8, 2010 Share Posted November 8, 2010 Well , I had mine fitted a couple of days ago on my aerodeck . Its really healped the ride , I am definately thrown around in the car a lot less !. In the process of getting 4 dampers fitted to , hopefully come friday its going to be like a different car.I bought all the bolts as described from EP82 and they all fitted great. Holes were gunked but I let the garage sort that out !. Link to comment Share on other sites More sharing options...
