MalkyT Posted July 1, 2011 Share Posted July 1, 2011 Hi, I'm running a 1.8 VTi Aerodeck (X reg, 2000) that has done 130,000miles. I have started hearing con-rod bearing noise for the last couple of thousand miles, and am after a thicker than standard oil to quieten the engine down and try and reduce wear as much as possible. I changed my oil to Fuchs Titan 5W-40 at the last change (bought from OPIE) and it made no difference to the noise. I'm trying to avoid a bottom end rebuild as I want to sell the car on soon.Could you recommend a thicker grade of oil for this mileage engine?Thanks,Malcolm Quote Link to comment Share on other sites More sharing options...
oilman Posted July 1, 2011 Author Share Posted July 1, 2011 Going for a thicker oil, such as a 10w-50 is likely to make it run quieter, but it won't be helping with protection, it'll just be masking the problem. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 15, 2011 Share Posted September 15, 2011 I usually use Castrol GTX 10w40 semi synthetic and was wonderin if the Millers Oils CFS 10w-40 will make any difference. pls let me know asap. thank u Quote Link to comment Share on other sites More sharing options...
oilman Posted September 16, 2011 Author Share Posted September 16, 2011 CFS is one of the top oils on the market and will give much better protection than the GTX Quote Link to comment Share on other sites More sharing options...
pj46 Posted November 9, 2011 Share Posted November 9, 2011 So i take it the best oil to use is 10w-40 in the MB6 vti-s engine then??when or would you use 20w-50?? Or wouldnt you use!?! Am trying to learn about Oils!! Quote Link to comment Share on other sites More sharing options...
oilman Posted November 10, 2011 Author Share Posted November 10, 2011 HiA 5w-40 is the best option as it will give better cold start protection than a 10w-40. I've never come across a non-vintage Honda where a 20w-50 is a good option.CheersTim Quote Link to comment Share on other sites More sharing options...
pj46 Posted November 12, 2011 Share Posted November 12, 2011 Thanks for advice Guy... Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted November 3, 2012 Share Posted November 3, 2012 I have bought Castrol Magnet 10w40 part-synthetic. I guess its the same meaning as semi-synthetic right? And I got Honda MTF in my gearbox, good stuff Quote Link to comment Share on other sites More sharing options...
oilman Posted November 4, 2012 Author Share Posted November 4, 2012 Yes, Magnatec 10w-40 is a semi-synthetic Quote Link to comment Share on other sites More sharing options...
Grant Posted January 4, 2014 Share Posted January 4, 2014 So am just about to order a load of parts for the MC. While there is some great info in this thread, I would find it beneficial to know what people are using and what is working for you. Are people sticking with the 5w 40 semi?? Or going fully syn?? I've used the Fuchs 5w 40 fully syn in the track civic which seemed fine. Quote Link to comment Share on other sites More sharing options...
