ep82 Posted November 22, 2010 Share Posted November 22, 2010 Got another Qmy driver window goes down slowly but going back up is ok. seems like it hasn't got enough power to pull the window down. is there anything I can do. all the other windows seems normal. Link to comment Share on other sites More sharing options...
BLouro Posted November 22, 2010 Share Posted November 22, 2010 Got The same Problem with the passeger side window does anyone solved this? Link to comment Share on other sites More sharing options...
dr_broon Posted November 22, 2010 Share Posted November 22, 2010 try a bit of multi purpose silicon spray on both sides (but not the bottom or it'll smear) - worked a treat for me.read it on another thread on here Link to comment Share on other sites More sharing options...
KiNK43 Posted November 22, 2010 Share Posted November 22, 2010 yeah, i had same problem.i took door card off and smeared loads of plumbers silicone grease on the rubbers. so far so good. much better. Link to comment Share on other sites More sharing options...
ep82 Posted November 22, 2010 Author Share Posted November 22, 2010 try a bit of multi purpose silicon spray on both sides (but not the bottom or it'll smear) - worked a treat for me.read it on another thread on here Not the bottom??? where can I spray it then is it worth take the door cards off like Jake or will spraying on the window also fixes that? Link to comment Share on other sites More sharing options...
dr_broon Posted November 23, 2010 Share Posted November 23, 2010 try a bit of multi purpose silicon spray on both sides (but not the bottom or it'll smear) - worked a treat for me.read it on another thread on here Not the bottom??? where can I spray it then is it worth take the door cards off like Jake or will spraying on the window also fixes that?just spray it on each gulley - you can spray it at the bottom of the gulley, just not the strip that goes along the bottom of the window Link to comment Share on other sites More sharing options...
BLouro Posted November 23, 2010 Share Posted November 23, 2010 Already done that, lot's off spray lol but it doesn't work problably will take off the door card's and lubrificate my elevator... Link to comment Share on other sites More sharing options...
scottravenhill Posted November 23, 2010 Share Posted November 23, 2010 I WASNT SURE IF I WAS GOING MAD OR NOT SOMETIMES FAST SOMETIMES SLOW Link to comment Share on other sites More sharing options...
KiNK43 Posted November 23, 2010 Share Posted November 23, 2010 Yeah, mine was slow in damp weather or cold nights only. Door cards come off so easy on these civics. Get in there and do the whole length of the runners. Should hopefully do the trick. Link to comment Share on other sites More sharing options...
ep82 Posted November 24, 2010 Author Share Posted November 24, 2010 Yeah I am going to spray the whole thing. if I am going to do something, might as well do it right.can I just ask how easy is it to take off the doorcards?I undone the 2 big screws on the door handle, 1 small screw on the open door latch, popped the tweeter trim out, pop all the bottom of the doorcard off. I tried sliding the doorcard up, it wants to but seems like something is still holding it down.do I need to remove the plastic trim around the open door latch? if so how do I do it. does it slide inplace? I tried pulling it out and it's in there tight! Link to comment Share on other sites More sharing options...
