Gav_ek4 Posted April 25, 2011 Share Posted April 25, 2011 took me 2 hours of constant hose squeezing and topping up to get coolant into the matrix on my mb6 when i changed the stat, in the end up i had to remove the hose from the heater valve on the bulkhead and fill the matrix with a funnel to get it bled...this was using boiled water to mix so the thermo opened on filling and eith the nose of the car up on ramps so gravity could do its job and help coolant into the matrix...b18s are a b*****d to bleed and it takes ages to do prop Link to comment Share on other sites More sharing options...
beaniexx Posted April 25, 2011 Share Posted April 25, 2011 seen before where the water pump blades actually come away from the pump which causes the water not to be circulated properly?also is the inlet pipe to matrix hot and outlet cold? if yes matrix could be blocked? Link to comment Share on other sites More sharing options...
IceMan Posted April 27, 2011 Author Share Posted April 27, 2011 Ok thanks for your help guys. Stat replaced and system bled. Needle not budging from about the quarter mark like it used too. Fingers crossed that will be the end of it. Link to comment Share on other sites More sharing options...
johngreen537 Posted April 28, 2011 Share Posted April 28, 2011 Cool. Glad you got it sorted! Link to comment Share on other sites More sharing options...
IceMan Posted April 28, 2011 Author Share Posted April 28, 2011 Managed to open the taps up on the way home and its still not budging. I'm going to miss this engine so bad... Link to comment Share on other sites More sharing options...
IceMan Posted May 3, 2011 Author Share Posted May 3, 2011 Oh dear.... its overheating again but the needle says all is ok.... RIP.... Link to comment Share on other sites More sharing options...
simpo Posted May 3, 2011 Share Posted May 3, 2011 how do you know its over heating if needle says ok? Link to comment Share on other sites More sharing options...
IceMan Posted May 4, 2011 Author Share Posted May 4, 2011 steam pouring out through the grill gave it away Link to comment Share on other sites More sharing options...
simpo Posted May 4, 2011 Share Posted May 4, 2011 so it was the head gasket? Link to comment Share on other sites More sharing options...
IceMan Posted May 4, 2011 Author Share Posted May 4, 2011 dont know for sure but with heating restored and the temp gauge reading norm a call to the garage says that its looking quite likely though they couldnt detect it. They said this is a sign that it may have finally let go. £500 quid for gasket , belt and labor they recon. Yikes at 125k im thinking no thanks but it would seem such a waste of a brilliant car Link to comment Share on other sites More sharing options...
