simpo Posted April 25, 2011 Share Posted April 25, 2011 we are just thinking worse case. but a new stat and a good bleed might sort it Link to comment Share on other sites More sharing options...
IceMan Posted April 25, 2011 Author Share Posted April 25, 2011 yer i told the garage when i took it in the stat is suspect but as they couldnt get it to over heat then i guess they are not willing to replace it. When i drop it off with steam pooring out then maybe that will prompt them . I'm scared of driving it now...precious honda Link to comment Share on other sites More sharing options...
simpo Posted April 25, 2011 Share Posted April 25, 2011 i wouldnt go driving it as you will probably just cause more damage. i have had a few hondas where one day it will be fine and the next day the temp would go up. so just because they couldnt get it to over heat doesnt mean the stat wasn't fooked Link to comment Share on other sites More sharing options...
johngreen537 Posted April 25, 2011 Share Posted April 25, 2011 how does a blown gasket lead to no heat from the fan heater and a cold pipe from the radiator?Stat 99% definately gone! Hot top hose, and cold bottom hose, means the stat is not working at all and is stuck closed!Bleed it properly first though, it's very different on a Honda than most VW's and such like!sounds to me like they have not bled it properly after doing the flush, causing an airlock and ultimately probably the end of your headgasket, honda engines dont take to being cookedX2 - Sounds to me like they've not bled it at all well! Take radiator cap off when cold engine, turn heater dials to FULL HEAT, then fans on full blow.Turn the engine on, then wait for it to warm up. IF the stat opens, you'll see big bubbles from the radiator, and the water levels drop. Keep them topped up.Once car is at normal temp, check bottom and top rad pipes to make sure they are warm / hot, if not, the stat is dead!TBH, if I had an overheating issue, and a possible airlock, I'd take the stat out completely, until you can get another new one! Take it out, then bleed the system off, you should have engine running too cold, which is obviously not ideal, but far far better than too hot! Link to comment Share on other sites More sharing options...
IceMan Posted April 25, 2011 Author Share Posted April 25, 2011 Ok going to try that out now. cheersbrb Link to comment Share on other sites More sharing options...
simpo Posted April 25, 2011 Share Posted April 25, 2011 Ok going to try that out now. cheersbrb dont come back to soon as it will mean you havent bleed it for long enough Link to comment Share on other sites More sharing options...
IceMan Posted April 25, 2011 Author Share Posted April 25, 2011 ok, heater on full beans and fan on full blast. No heat coming from them and no bubbles detected this was at idle, temp seemed normal and stable but i know if i drove it would rise. both rad hoses cold but the top one was starting to warm. I would imagine as there is no flow through the system that it takes a little time for any existing coolant in that pipe to boil. Link to comment Share on other sites More sharing options...
johngreen537 Posted April 25, 2011 Share Posted April 25, 2011 Rip the stat out! Link to comment Share on other sites More sharing options...
IceMan Posted April 25, 2011 Author Share Posted April 25, 2011 Rodger that. Where's good for replacements? Link to comment Share on other sites More sharing options...
noodels Posted April 25, 2011 Share Posted April 25, 2011 take out and test it in saucepan mate!bring to boil turn off heat and watch open /close, rubber gasket so no probs there!local motor factors parts place £10 Link to comment Share on other sites More sharing options...
