chris1400 Posted May 4, 2011 Share Posted May 4, 2011 Hi,think i have a big problem.Whent to my car this morning,a 95 1400 civic ma8.first of all the central locking dident work,then when i went to start it the indicators started flashing and it wouldent start,all the normal lights came on but no turn over or fuel pump sound.I have checked all the fuses.does anyone know whats happend,thanks chris Link to comment Share on other sites More sharing options...
beastgtir Posted May 4, 2011 Share Posted May 4, 2011 sounds like an alarm/immobiliser has kicked in hence the hazards going off? Link to comment Share on other sites More sharing options...
johngreen537 Posted May 5, 2011 Share Posted May 5, 2011 Does it try and crank when you turn the key? Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted May 5, 2011 Share Posted May 5, 2011 Could be battery, and only has enough juice to turn on lights etc? Link to comment Share on other sites More sharing options...
chris1400 Posted May 5, 2011 Author Share Posted May 5, 2011 it doesnt turn over,the battery is fine.i think either the ecu or central locking has packed up,but not sure Link to comment Share on other sites More sharing options...
simpo Posted May 5, 2011 Share Posted May 5, 2011 do you have a fob? Link to comment Share on other sites More sharing options...
chris1400 Posted May 5, 2011 Author Share Posted May 5, 2011 ye i have a fob.when i press it while the car is doing god knows what it just clicks and doesnt make a diffrence,it does turn the alarm off when i re conect the battery so the fob does work,im stumped.can only think that its something to do with central locking.is there a seperate box for the central locking? Link to comment Share on other sites More sharing options...
simpo Posted May 5, 2011 Share Posted May 5, 2011 does the fob still lock and unlock the doors? i think there is a box somewhere for the central locking Link to comment Share on other sites More sharing options...
chris1400 Posted May 5, 2011 Author Share Posted May 5, 2011 the fob didnt lock/unlock it when i got it it just turned alarm on and off.didnt bother me as i dont use alarm anyway.perhaps the problem started with that and has now got worse,im blaming the central locking,if my car has an imobilizer and thats gone haywire that would explain the non starting and the indicators as they are all linked. Link to comment Share on other sites More sharing options...
simpo Posted May 5, 2011 Share Posted May 5, 2011 sounds like an alarm/immobiliser has kicked in hence the hazards going off?does sound like immobiliser due to nothing happening when you try to turn it over. have you checked the fuses under the bonnet? maybe change the battery in the fob worth a try. have you tried sitting in the car and lifting the door pin up and down it see if it works the central locking? Link to comment Share on other sites More sharing options...
