markez78uk Posted June 28, 2011 Author Share Posted June 28, 2011 the dizzy isnt snapped i took cap off and rotor turns slowlyi have turned the car over with out even the dizzy in just to see the cam turnit turns very slowly and the starter motor spinns very fast im getting some one to take starter motor off to see if thats busteddo u think there could be any more damage inside (where starter motor fits in) ?i dont know sh1t about cars Link to comment Share on other sites More sharing options...
markez78uk Posted June 28, 2011 Author Share Posted June 28, 2011 ok its not the sarter motor fitted new 1 still doing the samepeople keep saying rotate 180 im worried as the teeth fit in the cam flush at the mo when i rotate it 180 it doesn sit flush this is how isheared my teeth last time from the dizzy the car sounds like it has no timing or compression stoopid me didnt mark the old dizzy up and threw it away any suggestions regards mark Link to comment Share on other sites More sharing options...
KiNK43 Posted June 30, 2011 Share Posted June 30, 2011 dizzy only goes in one way mate, so it cant be 180 out. as far as dizzy timing goes. we found that you should just be covering the mounting hole in the dizzy.so almost all the way to the back of the engine bay so the mount on the head is just covering the hole in the dizzy.when i had trouble rich also checked that the timing belt hadnt skipped a tooth by taking rocker cover off and checking that the timing marks lined up.have you checked compression??hope you get this sorted as it seems to be dragging on abit now ay. Link to comment Share on other sites More sharing options...
markez78uk Posted July 1, 2011 Author Share Posted July 1, 2011 dragging on is an understatementso took to another mechanic who said timing belt had skipped 7 teeth ? it will cost 270.00 to put new belt in and then told me car might not even start its a 270.00 risk i take as my valves may be bent !dizzy was put in wrong way snapped teeth on dizzy new dizzy fitted (right way) and now the above do you reckon the valves are bent ?would a compression test reveal if they are or not if so i may go ahead and get it done stoopid fkin vti s areodeck its getting donated to bottom of the fish pond ! cheers for help ! Link to comment Share on other sites More sharing options...
noodels Posted July 2, 2011 Share Posted July 2, 2011 £270 seems fookin expensive find another pvt persons for cash price!!sorry to hear of your trauma !!anyone want to earn few £s in morecome mssgs on a postcard plz to mark :0)never know mate worth a try init!! Link to comment Share on other sites More sharing options...
pjw Posted July 2, 2011 Share Posted July 2, 2011 Ive had similar issues, albeit on another car, and it turned out to be that the timing belt tensioner wasn't tensioning the belt enough. If youve done this recently maybe have a look. Link to comment Share on other sites More sharing options...
markez78uk Posted July 2, 2011 Author Share Posted July 2, 2011 £270 seems fookin expensive find another pvt persons for cash price!!sorry to hear of your trauma !!anyone want to earn few £s in morecome mssgs on a postcard plz to mark :0)never know mate worth a try init!!lol would be nice to have some one pop upthe last mechanic was useless and forced me to go to a private garage he charged me 70.00 to collect and bring back loltheres no more garages round here except cowboys and main dealers Link to comment Share on other sites More sharing options...
markez78uk Posted July 2, 2011 Author Share Posted July 2, 2011 gona get a new belt fitted and see if she starts if not off to the scrapyard !!! sad to see her go Link to comment Share on other sites More sharing options...
KiNK43 Posted July 2, 2011 Share Posted July 2, 2011 as far as i am aware these are non interference engines. meaning that the piston doesnt reach the valve. so should be ok. but the best way to tell i think is compression test all cylinders. if theres compression once the belt is on correctly then the valves are straight and seating properly. Link to comment Share on other sites More sharing options...
markez78uk Posted July 2, 2011 Author Share Posted July 2, 2011 as far as i am aware these are non interference engines. meaning that the piston doesnt reach the valve. so should be ok. but the best way to tell i think is compression test all cylinders. if theres compression once the belt is on correctly then the valves are straight and seating properly.cheers dude im gona av to pay him 270 to fit belt first to see if ok or can i check compression with the belt that is on (slipped 7 teeth apparently) ooh by the way all i did was turn key when dizzy was in wrong way car wasent even moving :0 Link to comment Share on other sites More sharing options...
