KiNK43 Posted June 11, 2011 Share Posted June 11, 2011 as above please.want to repaint my calipers but need them done quickly so all four apart and drying at the same time but only have two jacks.so one end of the car is gonna have to go on stands.just wondered where is the safest place to put them without damaging anything underneath.thanks for any help. jake Link to comment Share on other sites More sharing options...
ryan.. Posted June 11, 2011 Share Posted June 11, 2011 when we changed my drop links axel stands were put on the rear swing arms Link to comment Share on other sites More sharing options...
johngreen537 Posted June 11, 2011 Share Posted June 11, 2011 Depends what you need to access under the car mate, but generally, where LCA / wishbone meets chassis is easiest!Niceley shaped for stand tops too Link to comment Share on other sites More sharing options...
KiNK43 Posted June 11, 2011 Author Share Posted June 11, 2011 awesome thanks guys. so safe to actually put them on LCA and have the whole weight on them. Link to comment Share on other sites More sharing options...
johngreen537 Posted June 23, 2011 Share Posted June 23, 2011 Yes mate. Or If you are worried, and you hava jack that will lift the rear end high enough, sitck them on the jack points on the sills!You'll notice on your stands a little cut out section on the V bit, which is specifically designed for this! I had my EP3 on stands for 2 days on the sills waiting for drop links to turn up as I had to remove the LCA's to put on the subframe strengthener!You can see them in the bottom corners of this pic:You just need a jack that will lift the car high enough to get the stands under the sills! Link to comment Share on other sites More sharing options...
KiNK43 Posted June 23, 2011 Author Share Posted June 23, 2011 change of subject but your undercarriage is looking pretty sweet there! ha Link to comment Share on other sites More sharing options...
johngreen537 Posted June 23, 2011 Share Posted June 23, 2011 lol, wothout hijacking your thread, i got a shopping list as long as my arm to attempt before japfest The Mrs keeps moaning on about some wedding I'm supposed to be saving for though Link to comment Share on other sites More sharing options...
james Posted June 24, 2011 Share Posted June 24, 2011 wemon ,,,,,,,, thay just dont under stand Link to comment Share on other sites More sharing options...
johngreen537 Posted June 24, 2011 Share Posted June 24, 2011 Nope! It is our wedding, but, I keep thinking... OOOh D2's... Oooh Spoon.... oooh Skunk2.. Oooh Buddy Club And that's only for the LCA's, camber arms & camber correction bolts I want I'm being glared at. She's not looking happy. I might die soon. Link to comment Share on other sites More sharing options...
dr_broon Posted June 24, 2011 Share Posted June 24, 2011 wemon ,,,,,,,, thay just dont under stand heh heh... under... stand.... axle stands.... nice Link to comment Share on other sites More sharing options...
