Do1jonnyt Posted August 25, 2011 Share Posted August 25, 2011 Ok so today I had my clocks out to fit a vtec light. Everything worked when I took it out but when I put it back together the only thing that don't work is the dash lights and the clock stays on dim mode. I've had it all back out and disconnected/reconnected it all but still no luckHas anyone got any ideas what could be wrong? I've checked fuses oh and the lights on the heater controls works. Link to comment Share on other sites More sharing options...
simpo Posted August 26, 2011 Share Posted August 26, 2011 fuse? Link to comment Share on other sites More sharing options...
dr_broon Posted August 26, 2011 Share Posted August 26, 2011 double check that the plug for the dimmer is connected properly... that stops the dash lights working. 1"£££$££"!! Link to comment Share on other sites More sharing options...
steveolkinevel Posted August 26, 2011 Share Posted August 26, 2011 double check that the plug for the dimmer is connected properly... that stops the dash lights working. 1"£££$££"!!X2 happened to me! Link to comment Share on other sites More sharing options...
james Posted August 26, 2011 Share Posted August 26, 2011 double check that the plug for the dimmer is connected properly... that stops the dash lights working. 1"£££$££"!!X2 happened to me!x3 Link to comment Share on other sites More sharing options...
Do1jonnyt Posted September 3, 2011 Author Share Posted September 3, 2011 I found the problem. The connecter on the back of the clocks it pushed a pin out! All is well. Link to comment Share on other sites More sharing options...
