ryan.. Posted November 7, 2011 Share Posted November 7, 2011 hey guys, went to start the car this morning and it wouldnt start. First time I turned the key I heard the fuel pump relay go, all the appropriate lights came on but the pump didnt prime nor did the ecu make any noises. This happened before and it was the relay which had gone. Im going to check this, fuses and battery connections tonight when I get home from work but do you have any other suggestions as to what could be causing it? Link to comment Share on other sites More sharing options...
simpo Posted November 7, 2011 Share Posted November 7, 2011 two people had this problem in the last week. think it could be battery Link to comment Share on other sites More sharing options...
ryan.. Posted November 7, 2011 Author Share Posted November 7, 2011 im sure the battery is fine. after trying to turn it over it went back to 12.6v. Its got plenty of juice in it (being an optima yellow top 2.7L) i'll check it tonight along with the other things though Link to comment Share on other sites More sharing options...
knight Posted November 7, 2011 Share Posted November 7, 2011 Battery!!!!! mine was reading 10.9 and it wouldn't even turn!!!! Link to comment Share on other sites More sharing options...
ryan.. Posted November 7, 2011 Author Share Posted November 7, 2011 checked fuses. All fineMade connections on the battery better than they were (although they were tight)wouldnt turn overChecked voltage. Floating at 12.6. Gave it a few minutes charge. nothing, tried again and fires into life. Battery is now on charge. I charged it most of this evening and its now floating at 13v but its back on charge overnightA mechanic mate of mine thinks its ignition related due to the battery/handbreak light not coming on but the rest of the instrument lights do. I think I might have it checked out just to be sure Link to comment Share on other sites More sharing options...
ryan.. Posted November 8, 2011 Author Share Posted November 8, 2011 Looking at ignition switch being the culprit. Is number 12 on this page the switch?http://www.hondaoriginalparts.com/honda ... k_03=17233 Link to comment Share on other sites More sharing options...
noodels Posted November 8, 2011 Share Posted November 8, 2011 yep use multi meter to check Link to comment Share on other sites More sharing options...
ryan.. Posted November 8, 2011 Author Share Posted November 8, 2011 what do I need to look for when checking? Link to comment Share on other sites More sharing options...
noodels Posted November 8, 2011 Share Posted November 8, 2011 make sure you have power on the low and high curcuits in the relevent positions of the switch the low voltage will be the one to your solinoid and maybe the cause,once the switch is off you can put a screwdriver in the switch and turn it do do the above tests check for dry joints also / Link to comment Share on other sites More sharing options...
ryan.. Posted November 8, 2011 Author Share Posted November 8, 2011 I will give that a go. I've never taken that part of the car apart before, is it easy to access? bar the steering wheel obv Link to comment Share on other sites More sharing options...
