Didjeridave Posted December 11, 2011 Author Share Posted December 11, 2011 If turbo route ever gets going, I'll definitely be building the engine with forged, possibly even B20 at the same time? HA, now I'm dreaming!The weekend's seen the front arms rebushed, old rack out, new rack in place ready to figure out which bolts went where over the week...I'll get you some pics soon, honest. If it wasn't clarted in mud at the moment, there might be some sooner, but then the godsend that is my father-in-law's grain shed being dry, well lit & more importantly empty of grain way outweighs a splattering of farm track crap here and there! Link to comment Share on other sites More sharing options...
Didjeridave Posted January 30, 2012 Author Share Posted January 30, 2012 there's a little teaser of pics in the how to I'm putting up as I sort the geom. All Hard race suspension is now in & thanks to Jonnyricer I've slipped in a P28 with a fast road chip from H-tune If it wasn't for the utter pain t'int bum that is my utterly unexplained engine coolant sensor fault (all connections good, sensor tests OK, grrrr), I'd be slogging to get it sorted, but with daylight & crap weather it's sat waiting.Have to say that the short drive I've done with the DC2 rack didn't feel a much different at all, I'm wondering whether this idea that it's faster is true...Here's hoping for a dry weekend... Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted January 30, 2012 Share Posted January 30, 2012 Apparently its the same rack as the part number is the same? Link to comment Share on other sites More sharing options...
Didjeridave Posted January 30, 2012 Author Share Posted January 30, 2012 ...did manage to replace the heater blower switch with a switched 10k pot for my slightly unnecessary PWM motor control. It does go way past the 'IV' mark now though - I reckon this calls for marking it with 'XI' for full blast (apologies to any kids that haven't seen Spinal Tap). This will give fully adjustable fan speed, removes resistors from the air vents completely, so no hot bits of metal that burn out or big fat ceramics that cause loads of turbulence noise. Link to comment Share on other sites More sharing options...
Didjeridave Posted January 30, 2012 Author Share Posted January 30, 2012 yeah Wilksey, I'm pretty sure you're right. At least I know I've got a good rack in there with new inner/outer rods & gaitors, plus it clears up the issue. Next time I'm at the car I'll see exactly how many turns it makes lock to lock & post. Link to comment Share on other sites More sharing options...
noodels Posted January 30, 2012 Share Posted January 30, 2012 yeah Wilksey, I'm pretty sure you're right. At least I know I've got a good rack in there with new inner/outer rods & gaitors, plus it clears up the issue. Next time I'm at the car I'll see exactly how many turns it makes lock to lock & post. nearly got one for £70 glad i didnt now pheww!!looked at part numbers they are diffrent though, but same price, Mmm suspisious !!may be the difrent pipes ect thanks for the honesty mate Link to comment Share on other sites More sharing options...
Didjeridave Posted January 30, 2012 Author Share Posted January 30, 2012 I don't think they're the same part exactly. Pipes are funnily enough the opposite way around, at least with the rack I fitted. There's a 14mm hex connector & a 17mm hex. They both correspond to the same fitting, i.e. 14mm is in/out/[don't know which!] on both racks, but the position of the pipes on the rack is switched. At least, I swear that's how it seemed when fitting. I had all ends of problems trying to get the thing in because of very slight alignment issues; very easy to crossthread mounting bolts when all the steel piping is being twisted from what it should be. Frankly, don't bother! Link to comment Share on other sites More sharing options...
Didjeridave Posted February 21, 2012 Author Share Posted February 21, 2012 Finally sorted a basic geom after a snow/rain free weekend! Engine coolant sensor arrived, plugged in & code 16 vanished to reveal a code 22... A couple of ecu pin bridging mods later & finally have a fault free vtec-ing vti! Geom still not perfect, but I set 1mm toe in on the front so it tracks straight rather than faster turn-in. Reckon I'll try setting it parallel before commenting officially on the DC2 rack, although it does seem quicker; virtually any movement of the wheel sees the car turning. Not even sure if I prefer it!Have also replaced the heater blower with a PWM motor controller; it works but overheats; the 40W capability is clearly lies (blower motor 7W) - circuit to be redesigned with some fatter components.Slowly getting somewhere... Link to comment Share on other sites More sharing options...
NIKH25 Posted February 22, 2012 Share Posted February 22, 2012 Good work mate, keep it up. Link to comment Share on other sites More sharing options...
noodels Posted February 23, 2012 Share Posted February 23, 2012 hows the p28 any over fueling issues found a useful link as i was intrested in a spoon p72 but left it for now intresting read though..http://www.team-integra.net/forum/blogs ... asics.html Link to comment Share on other sites More sharing options...
