mb6loon Posted December 28, 2011 Share Posted December 28, 2011 ok guys ive been offered skunk 2 stage 2 cams for my mb6i know i'll have to get it remapped etc but do i need anything elseie like new springs and retaniners etc, any info would be a big helpthanks in advance Link to comment Share on other sites More sharing options...
weetec Posted December 28, 2011 Share Posted December 28, 2011 well kind of yes....im sure others will help more aswell...the duration of time the cam lifts the valves are increased or changed radically from your standard cam specs, thus altering the spring/retainer tolerances....the question is will your stock internals be able to cope with these new cams...it works for some but its a ticking time bomb.technically you could happily raise your revs and change gear all day long at the exact intervals....it could go on forever, but i very much doubt it....or you could happily drive along one day, have the need for speed and engage 2nd gear reaching lets say, 7000rpm and momentarily stay on the revs for a little longer in this gear for just a fraction of a second to judge your next move.........KABOOM....Mr Valve meets Mrs Piston....holy matrimony at last.its called valve float....easily googled and you tubed.....im sure i have missed many more catastrophes, but i will let other fellow members leave their humbled opinion....had it been this easy i most surely would of had been the test pilot on this one......hope this helps, naz. Link to comment Share on other sites More sharing options...
james Posted December 28, 2011 Share Posted December 28, 2011 interesting Link to comment Share on other sites More sharing options...
weetec Posted December 28, 2011 Share Posted December 28, 2011 interestingexcellent Video...bravo. Link to comment Share on other sites More sharing options...
noodels Posted December 29, 2011 Share Posted December 29, 2011 my thoughts i wouldnt go more radical than ITR cams or equivelent ek9/atr with the b18c4 head whithout porting it to get any gains as well as higher c/ratio,you might get less compression if this is not done as cam profile will get less fuel in the c/chamber due to its shape/flow rate capacity.so better pistons,port and gas flow,valve guide improvements,double cut or triple cut seats/ valve springs skunk2 site.and remaping increase rpm limiter to peak performance as in cam spec req............also an ITR flywheel/gearbox will see nice gains over oem the ITR cams+cam gear Link to comment Share on other sites More sharing options...
knight Posted December 29, 2011 Share Posted December 29, 2011 nice bit of info there chaps! nice one! 1"£££$££"!! Link to comment Share on other sites More sharing options...
james Posted December 29, 2011 Share Posted December 29, 2011 at noodles, always the man to bring you crashing down to earth Link to comment Share on other sites More sharing options...
mb6loon Posted December 29, 2011 Author Share Posted December 29, 2011 ok think i'll just leave it the way it is change inlet to a skunk2 though and a 70mm throttle bodie Link to comment Share on other sites More sharing options...
mb6loon Posted December 29, 2011 Author Share Posted December 29, 2011 and btw thanks for the info not worth breaking the car Link to comment Share on other sites More sharing options...
noodels Posted December 29, 2011 Share Posted December 29, 2011 at noodles, always the man to bring you crashing down to earth :lol:yes i am a party pooper dont want to see peeps waste time and effort and all that £sif i can"t ps dont bother with 70mm tb also make sure mani is for the bc4 head ect Link to comment Share on other sites More sharing options...
