Jimmer Posted December 29, 2011 Share Posted December 29, 2011 Hi folks, I just fitted an induction kit to replace the airbox, still has the original pipe to the inlet manifold, and when i took it for a test, you can hear the first stage of vtec kick in, but when the revs rise to around when the second vtec kicks in, i cant hear it coming in. The car still seems to pull well and does sound better but i wondered if you are meant to hear both stages kick in easily and what i can do? I have done some searches, but didn't read anythin that relates. Sorry for my dummy question lol, i would rather ask than guess lol. Link to comment Share on other sites More sharing options...
knight Posted December 29, 2011 Share Posted December 29, 2011 sound like your iab's arn't opening? at what revs can't you hear vtec? Link to comment Share on other sites More sharing options...
knight Posted December 29, 2011 Share Posted December 29, 2011 you should hear something at 6000rpm! Link to comment Share on other sites More sharing options...
Jimmer Posted December 29, 2011 Author Share Posted December 29, 2011 well the second stage is meant to have a noticable change in sound at 5.8k i think, is this right? cause i dont hear the engine note change around then. Although in first it still starts spinning from 6k up so im maybe be a spanner lol but its the fact that i can hear the first vtec comin in but not the second lol Link to comment Share on other sites More sharing options...
noodels Posted December 29, 2011 Share Posted December 29, 2011 ecu reset iabs open/come in at 5750in inlet manifold Link to comment Share on other sites More sharing options...
Shadz-VTIs Posted December 29, 2011 Share Posted December 29, 2011 this happend to me once .. i fitted an cold air feed and reseted the ecu did the job!!! Link to comment Share on other sites More sharing options...
Jimmer Posted December 29, 2011 Author Share Posted December 29, 2011 and for my next silly question lol, how do i reset the ecu? I have heard that many different ways for different cars that i may as well ask this also lol Link to comment Share on other sites More sharing options...
knight Posted December 29, 2011 Share Posted December 29, 2011 ECU Reset,,,After much Googling about resetting the ECU a variety of answers come up. None which seem to fully apply to the MB6 as usual Some of the literature says that Honda ECU's have a fuse that says "back up" or a fuse that says "ECU" and you should remove these. The MB6 has both After trial and error today I got a good result from the below.After getting the car warm I shut her down and took out the "ECU fuse 15A" and the "Back Up fuse 7.5A"Left it 10minStarted the car and just left her idling, you're supposed to leave it till it settles down to a smooth idle, [i left it idling for 10min as the fan activates after a certain point and it gives a chance for the fuel trims to include this].Shut the car down and started it back up straight away. [This is supposed to save the new fuel trim settings]. Link to comment Share on other sites More sharing options...
NIKH25 Posted December 29, 2011 Share Posted December 29, 2011 As above, do an ecu you reset, you should hear engine note change as iabs open and your face should do this Link to comment Share on other sites More sharing options...
Jimmer Posted December 29, 2011 Author Share Posted December 29, 2011 thanks mate, i will do this in the morning an let yous know if it changes anything. Cheers dude Link to comment Share on other sites More sharing options...
