knight Posted December 29, 2011 Share Posted December 29, 2011 thanks mate, i will do this in the morning an let yous know if it changes anything. Cheers dudeReport back! 1"£££$££"!! Link to comment Share on other sites More sharing options...
Jimmer Posted December 30, 2011 Author Share Posted December 30, 2011 Right did the ecu reset, although from what i could see there was no back up ecu fuse, the 7.5a one, although carried on and went through the motions but hasn't really made a difference. Still cant hear the second vtec coming in, but i can still feel the accereration improve lol. Baffled... Link to comment Share on other sites More sharing options...
knight Posted December 30, 2011 Share Posted December 30, 2011 you do have a mb6 yeah????? if you have then you will have that back up fuse!!! all are located in the engine bay fuse box! Link to comment Share on other sites More sharing options...
Jimmer Posted December 30, 2011 Author Share Posted December 30, 2011 Yeah mate I've a Vti-s, i had instantly thought when i saw there was no 7.5a fuse, there is a place for one, but i just thought a previous owner/mechanic didn't bother to replace it and that the car didn't need that fuse untill the 15a fuse broke, so i need to replace that when i get a 7.5a fuse, i only have 5's,10's an higher. Link to comment Share on other sites More sharing options...
noodels Posted January 1, 2012 Share Posted January 1, 2012 may want to look at this for testing and some infohttp://cars.homenetcs.co.uk/honda-civic ... g-iabs.htm Link to comment Share on other sites More sharing options...
Jimmer Posted January 1, 2012 Author Share Posted January 1, 2012 ill have a look at that tomorrow mate, the car is starting to drive better on changeover, maybe it just needs driven a bit after ecu reset to learn new settings when driving? Link to comment Share on other sites More sharing options...
Jimmer Posted January 1, 2012 Author Share Posted January 1, 2012 right had a check at this today and seems mine isn't working, when i switch on the ignition there is no movement from the linkage. it does move so isnt ceased, just no movement from it when the ignition comes on. Link to comment Share on other sites More sharing options...
KiNK43 Posted January 1, 2012 Share Posted January 1, 2012 There's a black unit bolted to the underside of the inlet manifold. I think its the charcoal canister but the vacuum for the iabs is controlled from there. Most likely needs replacing. You'll be happy when its fixed. knight lost nearly 30hp when his packed up. Link to comment Share on other sites More sharing options...
knight Posted January 1, 2012 Share Posted January 1, 2012 There's a black unit bolted to the underside of the inlet manifold. I think its the charcoal canister but the vacuum for the iabs is controlled from there. Most likely needs replacing. You'll be happy when its fixed. knight lost nearly 30hp when his packed up.Yeah! Thats the one! Link to comment Share on other sites More sharing options...
Jimmer Posted January 2, 2012 Author Share Posted January 2, 2012 Well I think after some poking around today again, you seem to be spot on with the iab not functioning. Tried the ignition on/off check, when nothing happened, and decided to close the vacuum pipe which should hold the iab open, but it made no difference at all lol. Car still sounds awesome but just cant hear the changeover at 5800rpm. I made a quick vid to show ya what i mean, sorry its not the best sound quality, but you should be able to hear it ok lol. Link to comment Share on other sites More sharing options...
