fyfie5 Posted February 10, 2012 Author Share Posted February 10, 2012 Nice!! cheers mate! Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted February 10, 2012 Author Share Posted February 10, 2012 Very nice,,, like the red stitching!thanks! i think im definitely set on a red and black theme now Quote Link to comment Share on other sites More sharing options...
DAVEMB2 Posted February 11, 2012 Share Posted February 11, 2012 Yer looks nice good thing about black you can put any colour with it and looks good 1"£££$££"! Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted February 11, 2012 Author Share Posted February 11, 2012 got my mugen oil cap and fitted it also my piping for my cold air intake! but not too sure how to install it is there a how to somewhere?also my wheels! rial 5 spoke alloys that i got very cheap off of ebay! but i need 2 front tyres as the guy before me used them on his mk2 track day car so saving up for them now! :D Quote Link to comment Share on other sites More sharing options...
vti_786 Posted February 12, 2012 Share Posted February 12, 2012 to fit the pipe on you would need to take the air filter box out and the rubber pipe that comes from your throttlebody.then affix the pipe which has one bend in it to the throttle body and the other pipe will fit the first pipe.the second pipe will feed down a hole left by the air filter box Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted February 12, 2012 Author Share Posted February 12, 2012 to fit the pipe on you would need to take the air filter box out and the rubber pipe that comes from your throttlebody.then affix the pipe which has one bend in it to the throttle body and the other pipe will fit the first pipe.the second pipe will feed down a hole left by the air filter boxill give it a go soon, when i get a cone filter for the pipe, thanks what about the little silicone pipe where does that go? Quote Link to comment Share on other sites More sharing options...
Guest Posted February 12, 2012 Share Posted February 12, 2012 to fit the pipe on you would need to take the air filter box out and the rubber pipe that comes from your throttlebody.then affix the pipe which has one bend in it to the throttle body and the other pipe will fit the first pipe.the second pipe will feed down a hole left by the air filter boxill give it a go soon, when i get a cone filter for the pipe, thanks what about the little silicone pipe where does that go?That's the rocker cover breather pipe it's pretty easy about 10 min job take stock piping off replace with stainless piping and cone filter and take the breather pipe of and replace with the blue silicone one. Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted February 12, 2012 Author Share Posted February 12, 2012 im a real amatuer and there are actually quite a lot of pipes connected to the original rubber pipe and some electrical plugs what happens to these? Quote Link to comment Share on other sites More sharing options...
Guest Posted February 12, 2012 Share Posted February 12, 2012 Ok so the stock breather pipe is connected parallel with a water pipe remove the stock metal part and make a joiner to connect the two water pipe together don't restrict the flow with whatever you use I cut the stock pipe opened it out nice and big made a joiner from that took 5 mins, remove the stock breather replace with the blue silicone pipe you have and once stainless pipe in place it connects to that. Not sure what electrical stuff is there may be an air temp sensor when I had a sohc it was a 1.6 vtec have anything electrical around the stock intake pipe, is yours a 1.4 non vtec? If it is then you should have a hole to accommodate it on your piping if not better get drilling.Good luck with it shouldnt be hard at all in true Haynes spirit I'd give it a 2 spanner rating if that. Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted February 12, 2012 Author Share Posted February 12, 2012 Ok so the stock breather pipe is connected parallel with a water pipe remove the stock metal part and make a joiner to connect the two water pipe together don't restrict the flow with whatever you use I cut the stock pipe opened it out nice and big made a joiner from that took 5 mins, remove the stock breather replace with the blue silicone pipe you have and once stainless pipe in place it connects to that. Not sure what electrical stuff is there may be an air temp sensor when I had a sohc it was a 1.6 vtec have anything electrical around the stock intake pipe, is yours a 1.4 non vtec? If it is then you should have a hole to accommodate it on your piping if not better get drilling.Good luck with it shouldnt be hard at all in true Haynes spirit I'd give it a 2 spanner rating if that.ok thanks for that, what do you mean by a joiner? water pipe? im so stupid i get everything else i think and mine is a 1.4 non vtec, ill get some pics up to ask what i mean Quote Link to comment Share on other sites More sharing options...
