dose my box need oil
LStuart06
after getting my vtis a few weeks ago i've quickly sourced most of the mechanical problems which are in the process of getting fixed but after doing an a full oil change and replacing the oil filter i've noticed a big difference in performance only thing is the gearbox doesn't crunch when driving normally but when going full pelt i've cot a crunch in nearly every gear. Is this signs of the gearbox oil needing replaced or is the box on its way out :?:
1"£££$££"
New Honda mtf can be a miracle cure. But could also be clutch or synchro problem. Unlikely synchros if all gears crunch though. I'd say change for genuine mtf and give it a few miles to work its way in. See if that helps.
