hard clutch pedal and not so good gear change
E=MC2
i just came from my friend mechanic
i bought new slave cylinder today, but he refused to change it because old one is free from any oil leaking, and by his opinion fully functional
by simple adjusting of clutch pedal he menaged to get little softer, and much confortable and convincing pedal feedback and allso menaged to significantly improve gear change, but still i have little gears rubbing feel on gearknob kombined with not so liquid gear change which is manifested with little delay between gears, especially on high revs
should i replace the slave cylinder anyway?
can be bad gear knob linkage geometry, because one engine mount is dead?
or you after all pointing your finger on the clutch set?
p.s. i hope that my sentences structure is not pretty bad :)
  • Replies 22
Top Posters In This Topic
i've changed slave, and nothing positive i didnt achieve
at first ride clutch was soft, and gear change precisious and without delays, but later, old problems came back
but i have noticed that when is warm outside, or when i warm, or even torture car for a while, gear change become very bad
can it be old fluid, not properly bleaded system, dead master cyl (which shows no oil leaks) or the new clutch set is my next investment :(
Bleed it Bleed it bleed it.... NEW FLUID NEW FLUID... start with the low cost options!!!
hehehe, loud and clear, i'll do that today
how to drain system from old fluid, and how properly to bleed it?
last time i was doing bleeding on bleed valve on slave cyl. Should i do that also on master, or the slave is the lowest system point?
