GreenVTi991 Posted March 23, 2012 Share Posted March 23, 2012 Driving on the motorway just now cruising downhill at 70 I let off the gas to slow down and noticed a plume of bluey-white smoke exit my exhaust. I sped up again then let off once more and sure enough another plume. Then as I exited the motorway and changed down through the gears – more smoke. Got to my destination, parked up and revved the car to over 4k, let off the throttle – no blue smoke.Blue smoke = expensive, right? Valve stem oil seals or piston ring failure, yes? Quote Link to comment Share on other sites More sharing options...
leejt1979 Posted March 23, 2012 Share Posted March 23, 2012 Basically.. yes mate... BLUE = burning oil in some form! BLACK = Fuel prob valve stems but i'd suggest a good service if youve not done it recently.. using a good 10w40 and a cheeky treatment maybe then hold tight and pray! Quote Link to comment Share on other sites More sharing options...
GreenVTi991 Posted March 23, 2012 Author Share Posted March 23, 2012 I've just checked the oil level and it's just above maximum.It's due a service as I last done it mid-Nov and have done about 6k miles. Would an oil additive help? If so, which one would you guys recommend, if any? I've read horror stories about additives over the years so don't want to compound the issue! Quote Link to comment Share on other sites More sharing options...
Krzys Posted March 23, 2012 Share Posted March 23, 2012 If it's above MAX then there's too much oil in there which may be causing the smoke? Quote Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted March 23, 2012 Share Posted March 23, 2012 If it's above MAX then there's too much oil in there which may be causing the smoke?Yeah i agree. Too much oil is just as bad as not enough! Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted March 23, 2012 Share Posted March 23, 2012 If it's above MAX then there's too much oil in there which may be causing the smoke?Yeah i agree. Too much oil is just as bad as not enough!x3 extra oil has to go somewhere, so gets burnt off.They love oil changes @ 6k it could definitely use one, additives and flushes not recommended.If you want to flush it, once you've drained the old oil add about a litre of cheap oil run it for 15mins - 1/2 hour, drain and fill with good 10/40. Quote Link to comment Share on other sites More sharing options...
GreenVTi991 Posted March 23, 2012 Author Share Posted March 23, 2012 Would the oil being just above max really cause the smoke? It was only a tiny bit above, like a fraction above the max hole. I'm a total dipstick if I did overfill it! Quote Link to comment Share on other sites More sharing options...
noodels Posted March 23, 2012 Share Posted March 23, 2012 doubt it if only just above when vhot,need more than 1 liter in to run for the above flush do a compression test drain oil replace, and measure how much was in Quote Link to comment Share on other sites More sharing options...
leejt1979 Posted March 24, 2012 Share Posted March 24, 2012 I always run mine just UNDER the max level... remember its a min/max level.... somewhere in-between is really ok.. people sometimes panic if it's not bang on the max level... no need Quote Link to comment Share on other sites More sharing options...
