MBK89 Posted May 13, 2012 Author Share Posted May 13, 2012 i do know 2 guys with DC2's might get luckyAlthough when it dies the intake makes a loud croak as if air is coming back through. Im thinking check the timing?? Quote Link to comment Share on other sites More sharing options...
noodels Posted May 13, 2012 Share Posted May 13, 2012 need to look at this may be helpfull testing although test rig needed for simulated advance problems with sparker ect need to send it away to test i did once cant remember where though was ages ago need the correct values ect for multimeter ect tell you in Haynes manual for specific ohms needed and how too ect may be better to swap dizzy http://easyautodiagnostics.com/honda_di ... tems_1.php Quote Link to comment Share on other sites More sharing options...
simpo Posted May 13, 2012 Share Posted May 13, 2012 Could be is your cam belt due? May of slipped a tooth Quote Link to comment Share on other sites More sharing options...
noodels Posted May 13, 2012 Share Posted May 13, 2012 simpo said: Could be is your cam belt due? May of slipped a toothgood starting point Quote Link to comment Share on other sites More sharing options...
MBK89 Posted May 13, 2012 Author Share Posted May 13, 2012 Cambelt was done Sept last year... Has been fine until now and once shes going its fine apart from occasional loss of power Quote Link to comment Share on other sites More sharing options...
shebabby Posted May 13, 2012 Share Posted May 13, 2012 could be a faulty fuel pump or blocked fuel filter ? Quote Link to comment Share on other sites More sharing options...
crazycustomz Posted May 14, 2012 Share Posted May 14, 2012 fuel related or dizzy.cant see it being the cambelt.dizzy is more common.are you running oem fuel pressure regulator? Quote Link to comment Share on other sites More sharing options...
MBK89 Posted May 14, 2012 Author Share Posted May 14, 2012 yeah cant do much checkin with the fuel... as i cant get a live data stream with the old 2 pin.Why else would i be getting air back through the intake???Yeah Diz and FPR are both OEM Quote Link to comment Share on other sites More sharing options...
shebabby Posted May 14, 2012 Share Posted May 14, 2012 wot did it run like before mate ?could you post a vid ? Quote Link to comment Share on other sites More sharing options...
crazycustomz Posted May 14, 2012 Share Posted May 14, 2012 a video would be a good idea.any black smoke on initial start up? Quote Link to comment Share on other sites More sharing options...
