DC2 ECu
stevovti-s
yes will run fine, but as said in another topic.
might just be better to a chipped ecu, a skunk 2 intake manifold and throttle body and type r b18C cams.
will work out cheaper tbh, wont be alot of difference in power
Pretty sure, yes mate. Search for P73, I remember a good while back someone else did the P73 thing!
Slightly wrong there! :)
Looky here:
viewtopic.php?f=62&t=6144&hilit=p73
P72 is Direct swap but you really need it socketing and a new map.
P73 doesn't let you use IAB's from what I remember, so you'd need to ditch the intake manifold etc.
The differences between the plugs on the ECU are minor, so a stanley knife will make it work :)
http://cars.homenetcs.co.uk/honda-civic ... ns-ecu.htm
I didn't think the c6 had iabs and I am pretty sure the ecu is obd2
p72 is the ecu from the jdm gsr, almost identicle engine to the b18c4 uk.
my friend has got an integra type - r, perfect for donor car. it might be sold but if not il let you know tomorrow.
its a ukdm with 80k on it, heavy damage to bodywork all round.
